Mark_and_Alice
| posted on 20/2/04 at 08:07 PM |
SVA failed
Results of SVA test on Monday (16th).......
Unsurprisingly, the car failed its first SVA test on Monday morning... however given the eventful trip to the centre it didn't go too badly. We
got a list of things to put right of which all except 1 have now been fixed - and the car is booked for its retest next Friday (27th). The test centre
was Birmingham Garretts Green, and despite our preconceptions the inspector was really friendly, helpful and complimented us on the car. Overall we
felt that the results and comments were fair. For reference the positive points were - nice handling/steering, looked good, not many points for a
first time amateur-built.
So, here's the list of what we failed on, and what we've done to correct it for next week. If anyone has any comments let us know!
"Dashboard lower edge is not radiused to 19mm" - the tester traced for us the curve of the inspection template which they use to measure
the curve. We've put 2m of pipe lagging (painted black) onto the bottom edge of our dash wherever it is exposed, ie not over the steering
column or where the dash meets the prop tunnel.
"Handbrake lever has edges less than 3.2mm radius" - we've filed off the edge where the handbrake button protrudes from the lever so
that it's a smooth curve down.
"Fusebox and metal bracket have edges less than 2.5mm radius" - we covered the fusebox and its mountings with a piece of foam then covered
it all in vinyl.
"Speedometer clock face edge less than 2.5mm radius" - having spoken to the test centre again about this, if the dial face sticks out less
than 5mm from the surface of the dash, they don't care what the edge is. So, we've sunk the speedo further into the dash rather than
file/pad out any edges.
"Rear number plate light not bright enough" - this was initially a problem as the rear number plate light was in series with other rear
lights. We've now wired the number plate light directly to the main loom - it means it's always on when engine is running, but it's
brighter!
"Front grill has edges contactable that are sharp" - hmmm, we had the standard MK grill on - say no more. We've now made a mesh
grill to replace the MK one.
"Back of headlight brackets are less than 2.5mm radius" - we had put U-trim on the front edges of the headlight bar, but didn't know
they also were needed on the back, so we've put them on now. We've also done the ends, for good measure, and put tape around the whole lot
to smooth off corners.
"Rear seatbelt mounting bolt heads and brackets contactable with edge less than 2.5mm radius" - we have made some natty covers for the
whole of the top seatbelt mounts, using pipe lagging but covered in black vinyl (the alternative suggestion was to put those SVA bolt covers on the
nut heads and then put some kind of rounded covering around the seatbelt brackets).
"Rear reflector edges less than 2.5mm" - we had put standard rear reflectors on, but because they stuck out from the rear wheelarch
surfaces by more than 5mm they cared about the edges. We've taken them off and put on reflector stickers.
"Wiring under drivers dash 'insecure'" - the fog light switch wires were away from the main loom and were not taped and
insulated. So we've taped and insulated them.
"Wiring from battery 'positive' uninsulated and insecure" - this was the red wire going from the battery positive to the fuse
box (not the main positive to the starter motor!). We've insulated it and made it more secure.
"Emissions too high" - we've got an appointment at a garage next Wednesday. The car was also misfiring on the way to the test
centre. Hopefully they will both be fixed once the garage have looked at the timing and mix.
We'lll keep you posted.
Mark and Alice.
macspeedy
| posted on 20/2/04 at 08:26 PM |
Unlucky seems thay can be over the top on radia but hopefully we can learn form them. Good luck with the re-test
alister667
| posted on 20/2/04 at 09:12 PM |
Thanks for all the details - it's good of you to post this info - as someone facing up to an SVA in a few weeks it gives me some points to
check.
Good luck for the retest.
http://members.lycos.co.uk/alister667/
bob
| posted on 20/2/04 at 09:16 PM |
Good luck with re test and thanks for the info on 1st test,dash radius seems pretty common lately.
I really should try and get a data base of most common test fails on MK owners site or forum,maybe chrisw might put one on here too.
OX
| posted on 21/2/04 at 12:05 AM |
good luck with the retest
Brooky
| posted on 21/2/04 at 12:33 PM |
code: Rear reflector edges less than 2.5mm
You cant help but think ' what a tosser ' its a piece of plastic on the back of the car for god's sake who is it going to hurt and
how?
One point mine failed on first time was the nut covering the lambda sensor hole in the exhaust wasnt radiused, I said that if some one was going to
injure them selves on that then radiusing wasnt going to help as it is between the exhaust and the side panel and red hot.
But rules are rules.
SteveO
| posted on 22/2/04 at 11:07 AM |
Thanks guys, i've got the same reflectors; i might just replace them like you did with sticker ones and put the other back later.
Did you make any adjustments for the self-centering test?
Best of luck for the re-test.
Mark_and_Alice
| posted on 28/2/04 at 06:21 PM |
Now Passed!
Thanks for the replies!
We have now passed. During the re-test a couple more things cropped up. We are posting these under a new topic.
All the best
Mark_and_Alice
| posted on 28/2/04 at 06:31 PM |
Self-centering
No adjustments were needed for the self-centering "test". The wheels had been aligned during the MOT though.
jacko
| posted on 28/2/04 at 06:32 PM |
Mark and Alice
congratulations with the pass
Jacko
