givemethebighammer
| posted on 24/4/04 at 02:15 PM |
Current regs on switches
What are the current regs on switches. I am interested in whether the hazard light switch has to have a light included in its construction, a separate
warning lamp on the dash or if both indicator lamps on the dash flashing together is sufficient.
Same question for the fog lamp switch.
thanks
Spyderman
| posted on 24/4/04 at 08:27 PM |
I believe that if the switch is illuminated when in operation then it doesn't need a separate indicator as long as it is visible. And flashes if
hazard switch.
If you have a separate warning light or both indicator warning lamps flash, then the switch does not need to be illuminated.
No doubt someone will correct me if wrong!
Terry
[Edited on 24/4/04 by Spyderman]
Spyderman
Tigger
| posted on 24/4/04 at 10:36 PM |
Almost right Spyderman
Hazard Lights need to have an indicator warning light with the correct symbol on it, both the indicator warning lights are not suitable.
Fog lights need a warning light too, all need to be visible from the driving seat and the fog lights must not come on with the brake lights.
Hope that helps
Tigger
NS Dev
| posted on 25/4/04 at 08:30 AM |
a divertion on the same theme, do you need two indicator warning lamps? Will one that works with both indicators suffice? I say this because many cars
have only one with two arrows on it.
| posted on 25/4/04 at 09:36 AM |
One is enough. If you can see the indicators from the driving seat you shouldn't actually need a warning light. You still need the one for the
hazard flasher though.
