gavin174
| posted on 8/5/10 at 05:19 PM |
sidelight tell tale
I am sure i read somewhere you now need a tell tale for sidelights..
is this correct?
if so what colur does it have to be.
Thanks Gavin
eznfrank
| posted on 8/5/10 at 05:40 PM |
a tell tale light or sticker? IIRC you don't need a light but there must be tell tale on or in the vicinty of the switch. Best check the book!
speedyxjs
| posted on 8/5/10 at 06:04 PM |
Yes you do
gavin174
| posted on 8/5/10 at 06:15 PM |
cheers speedy..
sort one problem and find another...
wasnt aware sidelights had to work with ignition off..
have to rewire them now them...
one step forward.... and all that.
Madinventions
| posted on 8/5/10 at 08:24 PM |
Can you just wire your speedo backlight into the sidelight circuit?
View my band website:
http://www.shadowlight.org.uk
russbost
| posted on 9/5/10 at 08:58 AM |
"Can you just wire your speedo backlight into the sidelight circuit? " - Yes, believe that is an alternative, but not all speedos have a
separately fed backlight - many are permanently o with ignition.
