daniel mason
| posted on 20/1/13 at 10:26 AM |
will i need to run a cat after engine install?
as some of you may know im in the process of converting a 1995 1.4 k series to a 2007 hayabusa in a 1995 M reg caterham.
will i need to run a cat? or can i get away without?
amongst all the second hand items i bought are 2 x 2-1 exhaust collector but one of them has a built in race cat,which when you look through it,looks
like its just packed with some wire mesh. and one is straight through! i would ideally like to sell one of these but not sure which one? cheers
Ben_Copeland
| posted on 20/1/13 at 10:34 AM |
Keep the cat for MOT just incase, use the straight through the rest of the year
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
ashg
| posted on 20/1/13 at 10:38 AM |
was it built with a cat? if it was you need to keep it, if not sling it.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
daniel mason
| posted on 20/1/13 at 10:42 AM |
dont think it had a cat unless it was built into silencer? and i only had it a few months before i ripped the engine out! so never mot'd it
deezee
posted on 20/1/13 at 10:54 AM |
As the car is already registered, its not the engine, but what kind of emissions test the car has to go through for its MOT. So if the car previously
needed a cat test before, it will need one after the engine change.
bigfoot4616
| posted on 20/1/13 at 11:35 AM |
is it not possible to have a map for the power commander that will get it through the cat test without a cat?
a good friendly tester would let you tweak it while he tested it.
daniel mason
| posted on 20/1/13 at 12:41 PM |
am running mbe ecu so maybe can get 2 maps. im gonna get sbd to send me some maps
adithorp
| posted on 20/1/13 at 05:57 PM |
If the car was SVA/IVA'd without then it doesn't need a cat' after and visa-versa... whatever engine you put in. It should have the
emission requirements on the v5 (although it wouldn't be unknown for DVLA to have missed it out). If it's on a Q plate then it
doesn't/shouldn't be tested for emissions anyway at MOT, just visable smoke.
If it was a pre-August 95 engine then it should be the pre-cat' test. The V5 will show CO <3.5% @ idle and HC <1200ppm.
If the V5 lists CO <0.5% HC <200ppm and Lambda 0.97-1.03 at fast idle and <0.5% CO @ idle, then it needs a cat'. No amount of tuning
will achieve that without a cat... unless you get a VERY helpful tester.
http://jpsc.org.uk/forum/
daniel mason
| posted on 20/1/13 at 06:16 PM |
got th v5 in front of me and there is no numbers at all after the emissions info in section V?
adithorp
| posted on 20/1/13 at 09:35 PM |
Not sure which section is which. Think you're talking about the bit for CO g/km for tin top emission (used for tax class on newer cars). The MOT
emission info for a kit is in the notes section (front page I think) if DVLA have entered. It's not there for older cars; Don't know when
they started putting it on.
