bart
| posted on 3/7/18 at 12:28 PM |
IVA cat and tripod bearing questions
Hi All
I have tried a search but nothing found , having said that bet its been questioned before
does the cat have to be E stamped for iva , I want to use a 3" 200 cell sports cat.
Tripod question not iva
does any one have the correct positions when installing a tripod joint
I presume at rest ie: neutral lift dive ect that the joint should be half way up the travel ,but then I suppose it depends on the intrusion into the
joint under dive and rise , any thoughts ? also engine movement !
BE ALERT > BRITAIN NEEDS LERTS
Slimy38
| posted on 3/7/18 at 01:22 PM |
There is no E stamp required for a catalytic converter, the 'proof of the pudding' will come when you have the car tested for emissions.
I've just had a look in the IVA manual and all I can see is that it needs to be secure, not leaking and not noisy.
MikeR
| posted on 3/7/18 at 01:33 PM |
Following as I'm interested in the tripod question
bart
| posted on 3/7/18 at 02:12 PM |
The tripod bearing question is not IVA related more of a design question.
