Krismc
| posted on 26/3/06 at 07:38 PM |
large wiring harness
how do i fix the 2 foot or so harness which is 1 inch thick??
from end of tunnel to near master cylinders in a vortx! does any one have any pics??
this bit here.>
Oh and does anyone know where to get a few p-clips 10 3/8th one 10 1/2 ones and about 5 1/4 ones im short either end of my fuel and brake lines?
[Edited on 26/3/06 by Krismc]
Chippy
| posted on 26/3/06 at 10:02 PM |
As its all in a nice piece of plastic trunking, why not just tie wrap it to the fuel pipe every three or four inches, its well insulated. Cant see
that would be any problem. ATB Ray.
David Jenkins
| posted on 27/3/06 at 07:16 AM |
If you tie it to the fuel pipe you're likely to fail SVA (with good reason).
Imagine if you had a short on the wiring and it overheated - right up against the fuel pipe!
You should keep wiring, fuel lines and brake pipes well clear of each other, as far as is practical.
To answer the original question - why not use tie-wraps to one of those screw-on tie-wrap mounts? Don't use sticky pads (not without a screw,
anyway).
Krismc
| posted on 27/3/06 at 04:08 PM |
good idea 'donkey'!?
and what about the small amount of p clips anyone know where to get a few
jos
| posted on 27/3/06 at 04:15 PM |
Same place as you got your p clips for brake lines would be my first port of call.
jos
| posted on 27/3/06 at 04:16 PM |
or http://www.tifosi.homecall.co.uk/cable%20ties.html
ady8077
| posted on 27/3/06 at 04:18 PM |
Hi
I got some large P clips from a local hydraulics shop, about a quid each
Failing that halfords sell tyrap bases that you can rivet to the chassis
Adrian
Krismc
| posted on 27/3/06 at 07:15 PM |
cheers guys illl probs order sum from the website as i need some p clips as well!?
