westf27
| posted on 7/5/06 at 09:39 PM |
sva noise level
sva retest 8.00am tomoz.Failed on 103db at 4250 rpm 2l pinto.Can we have a quick show of hands.....need some sleep,is that rpm 4250 too high my
reference says 3500rpm
smart51
| posted on 7/5/06 at 09:44 PM |
I seem to recall that it is 3/4 of the speed at which maximum power occurs.
4250 is 3/4 of 5666 RPM
wilkingj
Buy a Rev limiter
PS.. dont know the answer, but will find out on Tuesday! (SVA for me)
Best Regards
Geoff
http://www.v8viento.co.uk
Hellfire
| posted on 7/5/06 at 09:48 PM |
IIRC, you have to state on your SVA application form, the RPM at which max power occurs. It is this figure which then determines the noise test at 3/4
of the declared RPM.
Does that make sense?
Phil
westf27
| posted on 7/5/06 at 09:55 PM |
Thanks guys....goodnight
nitram38
| posted on 7/5/06 at 10:01 PM |
My engine revs to about 6000 (1.4 k-series) and Peak power is 4500.
So they should test at 3375 max?
russbost
| posted on 7/5/06 at 10:04 PM |
Depends what you declared on the SVA form Martin - should have read my article more carefully!!!
Hellfire
| posted on 7/5/06 at 10:12 PM |
westf27, good luck with the re-test tomorrow.
Phil
And from me!
[Edited on 8-5-06 by Hellfire]
westf27
| posted on 7/5/06 at 10:25 PM |
thanks phil sorted all the fiddlys only noise level iffy.fitted a db killer hope it works.might ask him to qualify his rpm value if it fails as it
appears my peak power rpm is 5500....3/4 of which is 4125
nitram38
| posted on 7/5/06 at 11:09 PM |
I put 4500 on the form!
Never mind, my car is quiet against 2 kwackers!
DarrenW
| posted on 8/5/06 at 09:07 AM |
My tester ignored what i put on the form. Tested at 3,900 rpm but i was well within (approx 93dB).
Good luck - sorry this reply was too late to help you.
irvined
| posted on 8/5/06 at 01:03 PM |
I put down 5500 on my form, guy let me sneakily change it down to 5000, it wouldnt have mattered in my case anyway, but i think if you've got a
good argument you can use a lower value, mine was that it simply doesnt rev that high
P.S 98db on one of those shiny cans i got last year.
http://irvined.blogspot.com
