Author: Subject: Koso RX1N: SVA friendly?
JoaoCaldeira
posted on 7/11/07 at 04:31 PM Reply With Quote
Hi.
To SVA a car with this unit, what additional lights / info should I have?
Hazard
Handbrake
Fog
Is there anything missing?
Joao
posted on 7/11/07 at 05:07 PM Reply With Quote
lamp to illuminate speedo
igh beam lamp
handbrake not needed but you need brake reservoir test lamp - a lot use the sme for both as indeed do Ford on the Sierra.
COREdevelopments
posted on 7/11/07 at 05:27 PM Reply With Quote
i hope its sva friendly as its what i got in my car. its well easy to wire up and iv only used an additional 2 lights, a brake warning light and alternator light.
rob
twybrow
posted on 7/11/07 at 05:48 PM Reply With Quote
Fog warning light, and brake fluid warning light are all you need (assuming you use everything else the KOSO has).
Paul TigerB6
posted on 7/11/07 at 06:13 PM Reply With Quote
sorry to hijack the thread but has anyone split the plastic casing and sandwiched the dashboard between the front and rear casing??
twybrow
posted on 7/11/07 at 06:31 PM Reply With Quote
I just spent ages with a grinder/file, and cut the outside shape out to recess the unit into my dash - it took bloody ages!
