Author: Subject: SVA Pass Leighton Buzzard
simonk
posted on 14/10/08 at 05:40 PM Reply With Quote
Good evening all.
Went very well and now have a shiny MAC to look at !! Bit of a challenge driving off at 06:30 in the dark and the mist in a brand new build car with no screen though ......
I discovered on the way there that the calculation that I had made for pulses on the speedo was clearly wrong, though I have been through them a couple of times now and they seem fine to me. It was a simple job to stop a few times on the way comparing indicated speed to Tom Tom speed and making the adjustments.
Doug the SVA man was very good and complementary about the car again which I guess is a good start. I only had to fettle two things on the test - a leaking brake T piece that needed nipping up and the exhaust clamps needed rotating a bit to avoid contact with the conical dalek that they use to test where the bottom of the car is.
Done in a little under two hours and able to enjoy a sunny drive back beaming like a cheshire cat. Mind you - discovered that leaves and grit sting at 70 mph !!
Cheers for all your help and support in getting me this far !
Simon
donut
posted on 14/10/08 at 05:43 PM Reply With Quote
Well done Simon.
Need some pix up now!!
jollygreengiant
posted on 14/10/08 at 05:49 PM Reply With Quote
Well done Simon. It looks as though my u2u and your post crossed each other in the dark.
Enjoy your driving and take care. I and the rest of the Luego gang look forward to seeing you and your car at some shows next year.
Enjoy.
adithorp
posted on 14/10/08 at 05:56 PM Reply With Quote
Nice one!
adrian
http://jpsc.org.uk/forum/
posted on 14/10/08 at 05:57 PM Reply With Quote
Nice one. See you and the car at a show next year perhaps?
simonk
posted on 14/10/08 at 06:05 PM Reply With Quote
Will be looking to take in all the shows I can next year.
Rusty Nuts, this bush/crush tube issue has clearly afflicted mine too - on today's drive the front seems to articulate nicely with very little stiction but the back end damn nearly smashed my kidneys a few times. Does anyone sell correctly sized replacements? I'm not really up for machining new tubes or shortening the bushes myself.
Simon
simonk
posted on 14/10/08 at 06:25 PM Reply With Quote
Today's pix in the archive now
Simon
