Author: Subject: rear fog, and reverse lights
RickRick
posted on 25/10/08 at 10:42 AM Reply With Quote
if i was to fit the rear fog and reverse lights low down (above the 250 min) in the center of the rear panel, with the number plate light pointing upwards would this pass?
the plan is to take them off, flip the number plate light over, and cover the holes with the numberplate
Dusty
posted on 25/10/08 at 10:45 AM Reply With Quote
You don't have to have a reversing light. The other two you do. No fog light is MOT fail. Single fog light can be fitted centrally or to the right side of centre.
[Edited on 25/10/08 by Dusty]
posted on 25/10/08 at 10:46 AM Reply With Quote
Maydo, however he may ask where your putting the number plate.
If its so you don't want the holes in the bodywork leave the reverse light off. You don't have to have one, just it must work if it's present.
RickRick
posted on 25/10/08 at 11:00 AM Reply With Quote
also what angle do the lights need to be at, mine are currently pointing slightly upwards
posted on 25/10/08 at 12:34 PM Reply With Quote
Just the fog light needs to be vertical, mine was just leaning back slightly to the eye but passed OK.
BTW. Cateringvans have the number plate light pointing up.
omega 24 v6
posted on 25/10/08 at 12:45 PM Reply With Quote
Bear in mind that if the no plate light is pointing up there must be no direct white light visible to the rear . i.e. you cant see the lens of the lamp.
