Author: Subject: security
RickRick
posted on 6/11/08 at 11:47 AM Reply With Quote
security
is a keyed ignition (but no steering lock), and an electonic imobaliser enough to cover the sva requireneants, or do i need some form of mechanical security
Mr Whippy
posted on 6/11/08 at 11:51 AM Reply With Quote
don't think so as someone could roll off with your car I'm sure the steering needs a lock
speedyxjs
posted on 6/11/08 at 11:52 AM Reply With Quote
Out of curiosity, are the IVA requirements for security the same?
m8kwr
posted on 6/11/08 at 12:00 PM Reply With Quote
this is directly from the IVA (Draft)
Method of Inspection
Check, in addition to the normal “ignition” switch, that the
vehicle is permanently fitted with an anti-theft device or an
electronic immobiliser that can be activated to prevent the
vehicle being driven or moved under its own power.
A mechanical anti-theft device could be a steering lock or
transmission lock. An electronic immobiliser can be
activated by the ignition key (so would not be obvious) or
could be separate - activated by a little fob type device
Evidence of compliance can be one of the following:
• Documentary evidence from a test laboratory
• Documentary evidence from the vehicle manufacturer
• An original certificate of installation from a Vehicle
Systems Installation Board (VSIB) accredited installer
Mobile Electronics and Security Federation
(MESF) accredited installer
Required Standard
1. A vehicle MUST be fitted with either a anti – theft device or an electronic
immobiliser
2. If fitted to the Vehicle, an anti – theft device
a. must be operational
b. must not operate on any part of the braking system
3. If it incorporates a mechanical part that acts upon a system used to control the
vehicle
a. It must Deactivate before the engine can be started
b. It must be deactivated while the engine is running
c. It must have a actuation which is a distinct and separate function from that
of stopping the engine
4. If fitted to the Vehicle, an Immobiliser must be accompanied by evidence of
compliance
Dangle_kt
posted on 6/11/08 at 12:06 PM Reply With Quote
So would two ignition keys be ok? One the normal ignition key, and one in another part of the car with a simple on/off - say on the passenger side.
It is an electronic form of imobilising the car, in as much as it is a secondary key which must be in the on position for the car to run.
I'd be interested in this, as this is how mine is set up curently...
mikeb
posted on 6/11/08 at 12:08 PM Reply With Quote
I thought the standard was
Ignition
Steering lock
Simple on/off with big red key
Mr Whippy
posted on 6/11/08 at 12:10 PM Reply With Quote
these are the killers of home fitted systems unless you get a garage to fit the immobilizer -
better off with the steering lock as at least some chav can't send your car off down a hill for a laugh...
Interesting that a locked handbrake is not acceptable
[Edited on 6/11/08 by Mr Whippy]
speedyxjs
posted on 6/11/08 at 12:15 PM Reply With Quote
Hidden under the dash of course
adithorp
posted on 6/11/08 at 12:21 PM Reply With Quote
Two forms of security required. They can be...
1. Electrical (ignition lock),
2. Mechanical (steering lock, gear change lock),
3. Electronic (immobiliser).
They can't effect the operation of the brakes.
Mine passed with dash mounted ignition lock/switch and an immobiliser.
adrian
http://jpsc.org.uk/forum/
omega0684
posted on 6/11/08 at 12:28 PM Reply With Quote
i went with the steering lock and the car key, inspector didn't even ask me about methods of security!
Dangle_kt
posted on 6/11/08 at 12:34 PM Reply With Quote
Yes hidden.
But is it acceptable?
flak monkey
posted on 6/11/08 at 12:38 PM Reply With Quote
I had an ignition key (no steering lock) and immobiliser for sva. No problems!
And yes, you could theoreticcally roll the car away!
Sera
http://www.motosera.com
adithorp
posted on 6/11/08 at 01:10 PM Reply With Quote
That counts as two (steering lock+ignition switch). Bit daft as, if you beat one then you've beaten the other but manufacturers got away with it for years. He won't ask if he can see its from a type approved vehicle.
The changes with IVA are to bring it in line with current type approval which requires an immobiliser.
As for not having a steering lock, I drop it in gear and the kids will never work out a bike box and get it back to neutral...and it won't start in gear either!
adrian
pocket rocket
posted on 6/11/08 at 04:24 PM Reply With Quote
lol your right, chavs are to dumb to work out a bike box... plus there only interested in nova's end saxo's so you should be safe
seriously tho you can get a handbrake/gearstick lock that will stop either being moved once the lock is on... no good for SVA but worth having maybe.
back to the question tho does a batt cut off switch count? not sure my focus ecu will like that tho, don't some ecu's need a constant feed?
Vindi_andy
posted on 6/11/08 at 04:26 PM Reply With Quote
sorry to be pedantic adithorp but reading that extract on page 1 of the post it appears a mechanical device such as a steering lock is acceptable so no different from SVA. you just appear to need documentary evidence.
I may be reading things wrong but thats how I would interpret that extract
quinnj3
posted on 6/11/08 at 08:11 PM Reply With Quote
I read it that you don't need a steering lock:
It states that in addition to a normal keyed ignition the vehicle must have either:
1) an electronic immobiliser
2) an anti theft device which could be interpreted as a steering lock.
You do not need both if I am reading the article correctly.
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
adithorp
posted on 6/11/08 at 09:32 PM Reply With Quote
Well that'll teach me to read all the post then and not make assumptions.
adrian
DarrenW
posted on 7/11/08 at 03:38 PM Reply With Quote
I removed the full steering lock bit from my column. Used dash mounted switch and start button and also an electronic immobilser fitted by me. Passed SVA no probs. IVA seems to request documentary evidence of the immobilser though.
Vindi_andy
posted on 7/11/08 at 04:15 PM Reply With Quote
adrian
Was not trying to be picky just trying to get things clear cos I havent got the SVA stage yet and probably wont get there before IVA comes in so I dont want to fall foul of the reg changes myself.
Using the original steering column with steering lock so hopefully that will count as both.
