phil m
| posted on 14/3/04 at 08:34 PM |
manual choke position
I've changed the webber to a manual choke . Am I right in thinking that I can put the control/handle in the exempt area that covers the area of
the dash in a circle just greater than the size of the steering wheel ?????????
Thanks , Phil
Lightning
| posted on 14/3/04 at 08:57 PM |
Not just greater but 127mm greater (6 inches) and anywhere on the offside of the wheel.
phil m
| posted on 18/3/04 at 06:57 PM |
Thanks Steve
Phil
| posted on 18/3/04 at 07:08 PM |
i didnt realise it was a full 6 inches you were allowed. I've squeezed nearly everything into the area visable thru the wheel!
highspeeddirt
| posted on 18/3/04 at 07:32 PM |
I have put all the non SVA compliant switches etc. inside the 127mm (5 Inch) exemption area and the rounded stuff outside. Just make sure you can
always read the speedo. I was going to use a sierra wheel for the test but the speedo was unreadable so I'm going to stick with the small
wheel.
| posted on 19/3/04 at 02:17 AM |
I removed the manual choke...
and fitted it on the wife... two hands around the neck sure choked her!
We were advised by MK not to put one on our 'bladed Indy... so far we haven't needed to either!
Better let go of the wife's neck now...
locoboy
| posted on 19/3/04 at 10:05 AM |
Mate of mine came up with a very nice idea, utilising the original bonet release catch under the steering column cowel.
Replace the bonet release cable with the choke cable and hey presto a nice neat and discreet location.
Locoboy
