phil m
| posted on 10/5/04 at 08:05 PM |
more self centering
The SVA manual asks for "a degree " of self centring when driven at 10mph+.
What exactly does this mean ? Is it when driven in a straight line , cornering , or both--.
phil
| posted on 10/5/04 at 08:20 PM |
Phil , you will find that when driving in straight line the steering is "centered". self centring means that steering will return towards
straight ahead if the steering wheel is released. find somewhere where you can try this on your everyday car , you will see what I mean . Rusty
| posted on 10/5/04 at 11:05 PM |
Self Centring for SVA
The SVA tester drives the vehicle with full lock on (no matter which as he tests both sides!) at approx 10mph. This way when he puts the wheels on
full lock and he lets go of the steering wheel it "attempts" to return to centre (straight ahead position). He then repeats this on the
other lock. If it attempts to return to centre it's deemed a pass.
HTH - <S>
We toe'd out our wheels 5degrees or more.
phil m
| posted on 11/5/04 at 08:09 PM |
Thanks for the info ------finally do they test centering when the car is going straight and the wheel is moved off centre only a little
thanks , phil
| posted on 12/5/04 at 11:42 AM |
They didn't on ours
Markp
| posted on 12/5/04 at 11:02 PM |
Only tested one side on mine
Thank god
Can't beat Nottingham
Mark
phil m
| posted on 13/5/04 at 08:17 PM |
I'm going to visit my test centre -Llantrisant (cardiff) to see if they can give me advice on this and a few other sticky points -----I'll
feed back next week if any relevent info comes up
Thanks for the replies ,
Phil
stressy
| posted on 14/5/04 at 06:58 AM |
Go find an empty space to play in, pump you tyres up to about 25-30psi and then adjust the front toe. you will probably find that with the right
amount of toe the car will have quit good centering but handle rather strangly.
I did thi for SVA and it was commented how much "feel" the car had when centering, i then brought it home, set the tracking back to normal
and let the tyre pressures down.
