spunky
posted on 22/5/04 at 08:06 PM |
Brake bias bar...
Hi guys,
Just doing last minute job pre SVA.
I've set the brake bias where I want it, I understand that Mr Inspector requires a roll pin or similar fitting into the bar.
Where exactly does he want it, and do I need one both ends.
TIA
John
Mk-Ninja
| posted on 22/5/04 at 08:17 PM |
I think the conclusion was that it should be pinned in a way that you cant adjust it without removing the pin/pins.
I'm sure I've got one, just don't know where I've put it
spunky
| posted on 22/5/04 at 08:19 PM |
Thank you MK,
John
bob
| posted on 24/5/04 at 08:43 AM |
I fitted a FIAT uno brake reduction valve in a simple bracket,a nut welded on the top to take bolt for adjustment with a hole through it for pin
fitment.
On my test i decided to take a chance and removed the screw/bolt for adjustment,it passed the braking test ok.
I did have a bit of a debate with the examiners,they said it was adjustable and i argued the point that only with an adjusting bolt which was not
fitted.
I may well have been lucky and set my valve in the bracket at just the right position.
Viper
| posted on 24/5/04 at 07:10 PM |
You are allowed to have bias adjustable brakes, but you must not be able to adjust them outside the allowed range.
