Author: Subject: What to do???
sb_scottmonkey
posted on 5/7/04 at 07:41 PM Reply With Quote
What to do???
Hi all, this is my first post on here... have come from MIGweb, GhostWalker got me onto this site.
My situation is this:
-New MK2 astra GTE 16v shell, no chassis number (bought with no docs or paperwork)
-Cavalier V6 rear suspension
-Calibra Turbo engine
-Calibra turbo front suspension
-Polybushes
-Exhaust yet to be made
-Lancia intercooler
-Home made aluminium dash (aircraft toggle switches + aircraft guages)
-No interior except 2 front seats.
Now then, how am i going to register this mix+match? all i've got to go on is an engine number....
Cheers, Scott
See: www.astragte.tk
ghost_walker
posted on 5/7/04 at 08:08 PM Reply With Quote
hope your mod bods on here don't mind me putting the link to this site on the site i use normally
scott go check out the tools section
there is only three speeds. fast, very fast and oh shit!!!
posted on 5/7/04 at 08:43 PM Reply With Quote
Is the shell legit?
If it's never been registered and is brand new you will need to go through the full registration process as you are building a new vehicle using parts from seperate cars. Contact your local VRO and get some info from them. You will most likely have an inspection and be allocated a vin number. They will also decide if your car is to receive a 'Q' plate which is likely, or if you are using mainly new parts a new registration.
Mark Allanson
posted on 5/7/04 at 09:07 PM Reply With Quote
If you can prove the origin of the shell (to the DVLA to say its not stolen), go the easy route. Buy an mot failure GTE, swap the parts (2 bodyshop fitters can do this in a weekend). MOT the car and then tell the DVLA you have shelled it, they may not inspect (I have done 5 shells this year without inspection).
Once you all legit, modify to your hearts content - and without a Q plate
posted on 5/7/04 at 09:18 PM Reply With Quote
Does it need to be a GTE ?
If you are doing it that way you don't have to have GTE parts and a bog standard Astra is going to be a lot cheaper, it's only a 2 door shell after all.
Mark Allanson
posted on 5/7/04 at 09:35 PM Reply With Quote
The DVLA would get all childish if you shell and change the spec of the car at the same time, don't confuse them (this happens really easily - the minnions always block anything they don't understand or are slightly suspicious of)
posted on 5/7/04 at 09:44 PM Reply With Quote
this bit is the only problem IMHO. the DVLA or the VI etc wont stand for this, without paperwork they will not believe it isnt stolen, unless you can supply details of the supplier. Is there any reason why you dont just use an old banger astra to provide the chassis, then there would be absolutely no worries about the power wielders. one simple letter about the engine swap, and no more worries.
best of luck anyway!
theconrodkid
posted on 5/7/04 at 10:53 PM Reply With Quote
the chassis no should be stamped on the chassis,think its on the strut top?use that to get a reg no
who cares who wins
pass the pork pies
NS Dev
posted on 6/7/04 at 07:29 AM Reply With Quote
-Polybushes
-Lancia intercooler
Cheers, Scott
Ahh, in Leicestershire I see, me too! Whereabouts are you, car isn't being built near Barwell is it, at Shane Golding's place?
Anyhow, I am in the hinckley area and may well be able to help you out. email me on n.seviour@ntlworld.com or call me on 07932 786471.
sb_scottmonkey
posted on 7/7/04 at 05:10 PM Reply With Quote
Many thanks for the Gen guys...
Seems liek the easiest was would be to do a standard re-shell, then the mods.. double the work but less paperwork!
The shell is a 16V GTE only shell, they had extra strenghtening up front and the gearchange linkage path is different (inside the car as opposed to underneath the floor)
The VIN number on astras is stamped beside the drivers seat, not on a strut top, and no there isn't one. Its blank.
I'm in near Lutterwortn, but know where Barwell is, have a friend there. I'm doing the project at home.
More details about the project on my website www.astragte.tk
Many thanks, Scott
