prawnabie
| posted on 17/6/14 at 09:19 PM |
Savage switches + IVA
Hi Everyone.
On my westy build I am using the MX5 instrument cluster and column switchgear, so the only thing that needs separate switches will be the heated front
screen, rear fog and the hazards. I want to use red illuminating savage switches for these and have them dimmed when turning on the sidelights and
dipped beam.
I will have the hazard switch wired up so it flashes fully lit when pressed as per the MX5, but as the instrument panel has tell tales for the rear
fog and heated screen, will I fail IVA if the switch light up fully when pressed as well as the tell tail on the dash?
Shaun
loggyboy
| posted on 17/6/14 at 09:34 PM |
As long as its clear and wont cause confusion then you should be fine.
Mistral Motorsport
