jos
| posted on 11/5/06 at 07:36 AM |
MOT - Fog & reversing light
At SVA the fog light has to be vertical & rearwards facing
What are the requirements at MOT. Does it only need to be operational.
Does the reversing light (if present) only have to be operational.
Its just last night the plastic bracket on my reversing light sheared off (i'll tell you how privately if you wish) and instead of buying a new
one, I was hoping to drill through my bodywork and mount both fog & reverse to the slightly inclined boot.
Humbug
| posted on 11/5/06 at 07:50 AM |
I think that for MOT the fog light just has to be functioning. Hope so, as I changed my SVA bracketed one for a rear panel mounted one the same as
what you are suggesting.
Re reversing light - not sure but I would guess it has to be working if it is there
| posted on 11/5/06 at 07:52 AM |
Mine passes with them on the rear panel without any comment. I changed them 3 years ago.
rusty
| posted on 11/5/06 at 08:03 AM |
My car got its SVA in 1984ish and does not have a fog light
jos
| posted on 11/5/06 at 08:08 AM |
Thanks rusty but if it did have one would it HAVE to be vertical or just operational.
I'm getting the impression it only needs to be operational for MOT (not that I'm having one soon)
DarrenW
| posted on 11/5/06 at 10:20 AM |
Jos - did you use the £4 lights off Mark with the plastic brackets??
Ive knacked 2 so far - they are weak when using your rear boot cover for recreational purposes. Did you belt buckle get snagged on the bolt??????
I just glued mine back on with bond and seal (the lights that is!)- jobs a good un for now.
jos
| posted on 11/5/06 at 10:46 AM |
I used the MAC#1 fog & reversing light and I think they had metal brackets with a hollow plastic feature to the light back.
I'm going to drill three holes for each, 2 to mount and 1 for cable in my rear panel and mount them to the body work rather than on the brackets
theyve got or are on now.
I'll wait for an email from Rich before doing so just incase I have problems later on if the fog light HAS to be vertical
