goodall
| posted on 22/12/06 at 12:14 PM |
hydraulic handbrake
hydraulic handbrake is it sva legal or do i need to get some rear calipers? like does it have to be mechanical can it not be hydraulic.
i know its along way off before i need to worry about this but just so i can start looking for the parts now if need be
chockymonster
| posted on 22/12/06 at 12:22 PM |
Rear handbrake has to be mechanical. Hydraulics are not allowed.
lsdweb
| posted on 22/12/06 at 01:43 PM |
But you can have both.
thunderace
| posted on 22/12/06 at 04:06 PM |
can you fit one for a mot??
hydraulic handbrake??
froggy
| posted on 22/12/06 at 04:32 PM |
you can have a hydraulic handbrake if you can obtain an exemption from vosa but it might be a bit difficult for a one off
quads with these fitted have been given an exemption at present due the threat of legal action from the manufacturers
zzr1100rick2
| posted on 22/12/06 at 08:04 PM |
Sorry to but in but how do these electric handbrakes work that seem to be in vouge for lots of cars MOT wise Rick
| posted on 22/12/06 at 10:22 PM |
quads with hydraulic handbrake should pass an M.O.T. test at the moment but customer should be informed they may not pass in the future according to a
recent VOSA message to testers
blakep82
| posted on 21/2/07 at 11:39 PM |
quote: Originally posted by CaLviNx
Because they are electromechanical, not hydraulic.
The electric actuators operate the cable's thus still making them still partially mechanical.
so does this mean, that i could do away with a handbrake and all the cabling, if i have some kind of electro mechanical system activate just by a
switch?
not entirely sure how it would work, but despite not being far on at all with my build, the hand brake is the only thing i can't work out
actually i've been considering whether it would be possible to have a drive shaft handbrake, where a brake disk is located on the prop shaft and
a caliper on the axle casing. search the net for 'drive shaft parking brake'
[Edited on 21/2/07 by blakep82]
Bob C
| posted on 22/2/07 at 11:52 AM |
that's what I did - check out my www
passed SVA without comment
works a treat!
Bob
blakep82
| posted on 22/2/07 at 06:32 PM |
Excellent! that'll he how i do it then. on the prop. thing is, I know most of the donors for cars on this site have props that are bolted to a
flange on the axle, sadly mine isn't. i'm sure it can be modified, mind you...
My car is a old race chassis i bought a fitting out for the road. its a pick up truck and is as wide and as long as a ford transit...
its the chassis from one of these
www.pickuptruckracing.net
[Edited on 22/2/07 by blakep82]
