ditchlewis
| posted on 3/7/07 at 02:56 PM |
SVA Fail at Norwich
well it failed, only on a few points.
head of the front indicator was loose.
emissions excessive (co2 ok, Hydrocarbons well over) this was due to the missfire it developed on the way up. one cylinder was not fireing and so
pumped all the petrol out...
upper seat belt mounts too low (due to to much padding in the seat bases.
the hand brake cover i used was not radiused to 3mm.
front coil spring collar not covered (protek the collar had gaps for the c spanner that need protecting)
fuel filter bracket of inadequate strength and durability
no evidence of a locking devise on the front brake calipers
speedo not working (checked when i got home and the magnets had come off  )
the lock on the stearing rack is to much and puts pressure on the flexable pipes as they inter the caliper, and the track rods touch the wing
bracket.
all in all a fair test.
there is a trainee tester currently at norwich so the test took 4 hours and there were many by the book discussions and advice taken from the old
hand.
some of the faults have already been put right, so its off to the garage again after seeing Rod Stewart tonight.
Ditch
| posted on 3/7/07 at 02:58 PM |
Sounds like a pretty reasonable fail....
New plugs should do the emissions (or was it a loose HT lead??? )
When's the retest???
ditchlewis
| posted on 3/7/07 at 03:05 PM |
i've swapped the plugs around and that did not help. so new leads it is
got to rebook yet but soon i hope, i will have to be sick that day
the other thing that happened was a fuse blew and i had no lights      this was the first test   fixed it whilst they had a
brew.
ditch
| posted on 3/7/07 at 03:13 PM |
Bad news but not for long.
Get it done quick, I want to see the girocopter started
| posted on 3/7/07 at 03:34 PM |
I went over to Capel on the off-chance to see if Ditch was back home - had a quick chat and a nose about. Everything's easily fixable I
reckon.
Well done!
ditchlewis
| posted on 3/7/07 at 03:44 PM |
it was a good suprise to see you david  .
yes it is all easily fixable, just time. at least the wife is working some nights this week so i will have some garage time.
i was down to sart with but by the time i got home it was all ok.
at least i had a good 100 mile round trip.
Ditch
| posted on 3/7/07 at 03:47 PM |
that's not a bad fail at all, let's hope Rob Stewart can fix it. (think Jim wouldhave been better).
| posted on 3/7/07 at 05:17 PM |
I hope you got it back under cover in time, before the lightning/rain/hail hit! As I was talking to Ditch, we could see huge black clouds developing
not too far away.
According to the local news, Capel got 12mm of rain in 20 minutes.
Lucky your SVA wasn't this afternoon!
Paul (Notts)
| posted on 3/7/07 at 05:26 PM |
Starting to think about my SVA -what do you mean by
Paul
wilkingj
| posted on 3/7/07 at 07:52 PM |
Well Done, thats not a bad fail at all.
You will soon get those bits fixed up.
You will soon be out in the summer rain
Best Regards
Geoff
http://www.v8viento.co.uk
darrens
| posted on 3/7/07 at 09:20 PM |
Paul
Was also just quandering this as I forgot to put on the retaining/anti rattle brake pad springs on the front. No questions asked tho.
Not a bad fail tho really, seems pretty straight forward fixes and should prove to be a sucessfull retest. It is a semi nice feely that after spending
all of that time building/swearing and distroying your knuckles that nothing major fails. Looks a good motor!!
[Edited on 3/7/07 by darrens]
ditchlewis
| posted on 4/7/07 at 08:03 AM |
the retaining/ locking for the front brake calipers was one that took me by suprise, it is about holding the caliper to the hub, but locktite will be
sufficent as long as you give the answer when asked... i knew i had failed by that time so i did not bother bulls~~~ing. i suppose that locking
washers may be acceptable but the ford sierra did not have them.
yes i got in before the rain and got brownie points for remembering the washing
glad we had not paid for tickets to sit on the pitch, they were soaked           Rod had to stop to dry his equipment out
ditch
[Edited on 4/7/07 by ditchlewis]
| posted on 4/7/07 at 05:24 PM |
Think someone on here once posted a diagrahm for the locking tabs ? Easy to make .
