Valtra
| posted on 26/6/08 at 01:09 PM |
perferated (spell?) exhaust heat shield
Is it Sva friendly to have a perferated heat shield on my exhaust ? and is there a heat proof edge trim for the ends of my silencer (old but unused
Caterham) or heat shield if I fit it for SVA ?
Ta
10th July looming large now
Mr Whippy
| posted on 26/6/08 at 01:21 PM |
so long as the perforations are pointing in the way. Old washing machine drums seem to be popular.
| posted on 26/6/08 at 01:37 PM |
recommended practice is not to fit one due to the holes (sharp edges) and the edges; you can fit rubber trim round that but some sites frown on rubber
bits being fitted to exhaust systems = fail.
funnily enough, SVA does not care if the passenger's legs get burnt on the exhaust.
so do not fit unless you have a good reason to i.e. it hides sharp edges.
| posted on 26/6/08 at 02:05 PM |
If you want one, best to fit it post SVA....
SVA mentality:
Sharp edges BOOOOOOOOOOO
Glowing red hot exhausts- Yey!!!!!!!!
Valtra
| posted on 26/6/08 at 04:36 PM |
Thanks guys . as I suspected the only problem is now that the silencer box ends are the traditional type. the edge is thick and smooth welded but will
it need a trim to save grazing the neck of the pedestrian that' made it un-scathed through the front suspension ? any simple sugestions
greatfully received
