ian.lucas
| posted on 4/7/08 at 04:22 PM |
headlight set up
what is the best way to set up headlights for sva test??
stuart_g
| posted on 4/7/08 at 04:35 PM |
don't bother do it on the day.
| posted on 4/7/08 at 05:55 PM |
Yup. As long as its quick and easy to do they'll let you fiddle during the test.
I took mine for a "MOT" before the test and did it then but its not necessary...
asn163
| posted on 4/7/08 at 08:15 PM |
Don't. worry about it, as said above you can probably do it during the test. In fact during ours, the tester actually tweaked them for us.
saigonij
| posted on 4/7/08 at 10:04 PM |
you can get it roughly right by driving your tintop up to the garage at night with the lights on, and make a note of where the pattern falls, then do
the same with the kit car.
its not precise but at least it will show you tried.
RazMan
| posted on 5/7/08 at 07:07 AM |
I set mine up like that - park the tin-top about 30 feet from the garage door, stick masking tape where you see the 'cut-off' on the door
and then replace tin-top with toy car and tweak as neccessary.
Raz
