bilbo
| posted on 20/11/08 at 01:39 PM |
Unleaded Nozzle Size
I'm planning on fabricating my own unleaded filler cap restrictor for SVA/IVA.
Can anyone confirm what diameter it should be? I've read somewhere 3/4" is the actual nozzle size, but as this was an american site,
I'm not sure it's the same for Europe?
Bill
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
iank
| posted on 20/11/08 at 01:48 PM |
Needs to be 23.6mm or less, and as close to the top of the filler cap tube as possible. According to SVA manual 15.2.1.b
Why the insane level of accuracy I know not, though it's close(ish) to 15/16"
Anonymous
bilbo
| posted on 20/11/08 at 02:10 PM |
Great, thanks for the quick reply.
I guess I could probably get away with 22mm as a more sensible size?
Richard Quinn
| posted on 20/11/08 at 02:20 PM |
Sorry in advance for the hijack! I have a fabricated ally tank with a screw on type knurled ally cap. Is it possible to get a restrictor to fit this
type of neck or do I need to machine one?
TIA
scotlad
| posted on 20/11/08 at 02:24 PM |
Do you have to have a restrictor in the fuel filler even if your using a pre-cat 1993 engine as they didn't have to run on unleaded (or did
they?)? I was wondering if i could get away without one on my Robin Hood.
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
matt_claydon
| posted on 20/11/08 at 02:54 PM |
You only need the restrictor if you have a cat.
jabbahutt
| posted on 20/11/08 at 03:03 PM |
yep restrictor only if a cat is fitted. Wish I knew that before buying and fitting one
Oh well at least it should stop me putting the wrong fuel in when I experience one of my many stupid moments
iank
| posted on 20/11/08 at 03:22 PM |
22mm was less than 23.6mm the last time I checked It will be fine
Anonymous
blakep82
| posted on 20/11/08 at 03:43 PM |
hmmm, don't much see the point in these restrictors any more, since you can't get leaded fuel to poison a catalytic convertor anyway.
unless its to stop you putting diesel in, in which case, why does it matter if you have a cat or not? it should then be in all fuel fillers surely?
________________________
bigrich
| posted on 20/11/08 at 07:07 PM |
the big washer from a Sierra rear driveshaft makes a great restrictor
Richard Quinn
| posted on 20/11/08 at 07:50 PM |
Is the centre hole an acceptable dia?
