spdpug98
| posted on 29/12/08 at 12:24 PM |
SVA Bike Clocks
Tried a search but could not find the answer
Has anyone had any problems using the standard bike clocks in the centre of the dash with the SVA
I am planning on using the standard R1 clocks in the middle of the dash and was hoping it would'nt be a problem
My Blog: http://spdpug98.wordpress.com/
iceman26
| posted on 29/12/08 at 12:35 PM |
iuse my fazer ones with no problem just put some large o rings aronud the raised edges
adithorp
| posted on 29/12/08 at 01:06 PM |
Mine passed ok without comment. I put a hood over it to stop them getting the head-form thing too near as the left hand side was outside the exclusion
zone. As it turned out they never checked the radii with the tools, just ran his hand over.
http://i189.photobucket.com/albums/z282/adrianthorp/Pre-SVA003.jpg
adrian
http://jpsc.org.uk/forum/
eznfrank
| posted on 29/12/08 at 01:58 PM |
You may well need a speedo healer too.
spdpug98
| posted on 29/12/08 at 02:07 PM |
Thanks for all the replies, looks like I should be OK, are they just fixed directly through the dash and did you have to round the main edges of the
clocks
Thanks for the heads up on the speedo healer but I have one on order with my kit.
stuart_g
| posted on 29/12/08 at 03:08 PM |
Why not make a fiberglass housing for them and sink it into the dash as I did. It passed SVA as it is and angles the clocks toward you so they are
easier to read.
adithorp
| posted on 29/12/08 at 03:14 PM |
I made a template in card that it sat in. Then transfered that to the dash and cut it out. I used the mounting holes in the back to bolt it to the
dash with brackets, with the clocks in from the rear up to the ridge that runs around them.
I didn't round off anything on the clocks. I just used the "hood" to stop them getting the head-form in near it. The hood was due to
fall off after SVA but it grew on me... and stops the passenger reading the speedo!
Picture without hood...
http://i189.photobucket.com/albums/z282/adrianthorp/fury087.jpg
...and the hole...
http://i189.photobucket.com/albums/z282/adrianthorp/fury082.jpg
adrian
spdpug98
| posted on 29/12/08 at 03:20 PM |
easier to read.
I like that, it looks the business...I think I may go that way
bassett
| posted on 29/12/08 at 05:50 PM |
Just wondering why does no one put them behind the steering wheel like in your everyday tin top?
adithorp
| posted on 29/12/08 at 06:46 PM |
I didn't have enough room.
adrian
stuart_g
| posted on 29/12/08 at 07:38 PM |
I wanted the clocks to be behind the steering wheel. It would have been a nightmare mounting them with all the different angles of the scuttle panel
and with my OMP steering wheel I fitted after SVA I wouldn't be able to see all of the dash.
bigrich
| posted on 29/12/08 at 11:55 PM |
heres mine
