Author: Subject: fuel line
cjtheman
posted on 4/1/09 at 04:00 PM Reply With Quote
fuel line
hi all
i have fitted my copper fuel line
do i need written proof that the flexi that connects to the tank and carb is right grade or will whats stamped into it be good enough
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
Stuart_B
posted on 4/1/09 at 04:24 PM Reply With Quote
hi, i got written proof about my fuel hose from my local motor factor teh chap was more than happy to help, but i am not sure if you need it. if you have not brought the hose yet try your local motor factor, they might give you a photocopy of there catlogue say what it is fit for and all the numbers, because that is what mine done.
stuart
flak monkey
If its marked with the correct markings it will be fine. If not, you'll need a reciept or something to prove its fuel resistant.
Most rubber fuel hose is marked.
Sera
http://www.motosera.com
