Author: Subject: fuel line fixing
cjtheman
posted on 6/1/09 at 06:16 PM Reply With Quote
fuel line fixing
hi all,
can you tell me the max for fuel line centre's
cheers colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
adithorp
posted on 6/1/09 at 06:24 PM Reply With Quote
As with brake pipes it's not specified in the SVA manual. It does say 300mm max for wiring looms. I think mine is cliped about every 200mm.
adrian
http://jpsc.org.uk/forum/
l0rd
posted on 6/1/09 at 06:44 PM Reply With Quote
Do you mean the distance between P Clips?
The Draft IVA says only securely fitted.
Stuart_B
posted on 6/1/09 at 08:28 PM Reply With Quote
i think i clipped my every 100mm or 150mm, that is for fuel, brake and wiring, i done.
stuart
l0rd
posted on 6/1/09 at 08:47 PM Reply With Quote
I would believe that both the loom and all the pipes should be equal to 30cm or 300mm apart.
cjtheman
posted on 7/1/09 at 07:09 AM Reply With Quote
cheers guys
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
