Author: Subject: Zetec Without a CAT
mccsp
posted on 7/1/09 at 10:43 PM Reply With Quote
Zetec Without a CAT
Is the Zetec a special case when it comes to SVA and the need to fit a CAT.
A recent thread said pre August 95 and no CAT required, but I was under the impression that if the engine was post 92 a CAT would be required.
Any feedback would be greatly appreciated. I am about to order my exhaust and would rather not have a CAT.
My engine has 94 cast into the block, which I am led to believe means it was built in 1994, do I need any more proof than this of its age?
Thanks in advance.
mad-butcher
posted on 7/1/09 at 10:57 PM Reply With Quote
any idea when the donor car was 1st registered. I believe you can check engine numbers on the burton power website
mad4x4
posted on 7/1/09 at 11:09 PM Reply With Quote
My serria was an H reg but I went to SVA with a letter from FORD say engine was pre 92 from an early mondeo
Man from SVA said OK - no CAT
stuart_g
posted on 7/1/09 at 11:13 PM Reply With Quote
As above check on the burton power website. You will need your engine number to cross reference on the chart to get year of manufacture for the engine. This may be enough to satisfy the SVA tester as some people have used the same sort of info from haynes manuals, failing that I beleive you can get ford to confirm engine date and get them to send you a letter as proof.
Pretty sure pre august 95 engines do not need a CAT.
mccsp
posted on 7/1/09 at 11:14 PM Reply With Quote
Was your engine actually pre 92?
mccsp
posted on 7/1/09 at 11:20 PM Reply With Quote
I am struggling to find the chart on the Burton Power Website, a link would be greatly appreciated
stevebubs
posted on 7/1/09 at 11:30 PM Reply With Quote
It was 1992 that Cats started to be mandatory on all new *production* cars but there were exceptions for a while.
For SVA purposes, August 1995 is the key date. So long as your engine was *manufactured* before this date, then you don't need a Cat.
mccsp
posted on 7/1/09 at 11:40 PM Reply With Quote
thanks Steve,
I thought this was the case until recently came to question it when one of the Kitcar mags had an SVA guide that referred to 1992 as the cut off date.
Can't remember which one of the top of my head.
[Edited on 7/1/09 by mccsp]
posted on 8/1/09 at 07:03 AM Reply With Quote
Belt & Braces.. send your engine number off to Ford Technical Services, they will reply with a letter stating the month and year of manufacture.
Any engine pre August 95 does not need a CAT at SVA.
Ford Technical Information Centre
PO Box 300
Walsall
WS5 4QH
fax 01922 725266
blakep82
posted on 8/1/09 at 08:42 AM Reply With Quote
not wanting to hijack, but if you accept the engine was made after 1995 (mine's a vauxhall ecotec engine) and fit a cat, do you still need to prove the engine age?
________________________
bill132hotrod
posted on 8/1/09 at 10:55 AM Reply With Quote
CAT Query
My engine is a C20XE and was built as a cat engine with a cat on it, Engine number check came up as being fitted to a 1991 model calibra 3 door coupe 16v 2.0ipetrol with a catalytic converter, the actual engine was built sept 1990, i went for SVA dec 19 2008 (NO CAT REQUIRED AND NO RESTRICTER IN FUEL FILLER REQUIRED EITHER) passed ok.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
stuart_g
posted on 8/1/09 at 11:21 AM Reply With Quote
Here is a link to the date chart on Burton power web site
mccsp
posted on 8/1/09 at 12:40 PM Reply With Quote
Thank you everyone, I think that answers all my questions.
posted on 8/1/09 at 09:42 PM Reply With Quote
Yes, if you don't prove engine age the SVA man will apply current CAT emissions, ie: 2009 standard, tight as hell.
Different standards through the years so better to prove age to get the correct emission year.
