Danozeman
| posted on 12/1/09 at 11:08 PM |
v55/5 answers.
What do you put on:-
7 - type of body
8 - wheel pan
11 variant
12 version
13 length do i actually need to measure it?
14 hc
15 unlaiden weight 900??
17 max net power ? 1.8 zetec?
i asume the towable mass leave
19 width do i actually need to measure it?
21 revenue weight
23 max permissible mass do i need to fill in the sound bit etc?
Dan
Lars
| posted on 12/1/09 at 11:10 PM |
If that is the form to register your car then just take it to the DVLA, they'll run you through it.
Lars
| posted on 12/1/09 at 11:11 PM |
but from memory most are not applicable
Danozeman
| posted on 12/1/09 at 11:14 PM |
I wanted to give them less to do to hopefully make it more painfree
Dan
adithorp
| posted on 12/1/09 at 11:21 PM |
Have you not got the notes booklet that is supplied with the forms from Swansea?
Most don't apply to kits. If in doubt leave it blank and DVLA will sort it when they inspect.
7, is Sports
the rest are n/a I think from memory.
adrian
http://jpsc.org.uk/forum/
adithorp
| posted on 13/1/09 at 08:30 AM |
Just checked the notes.
7, sports
8, 2 axle rigid
all the rest N/A as the answer are either not required for cars under 3500kg or require answers from a CofC (ie. type approved).
adrian
