Author: Subject: Collapsible steering boss
andrew.carwithen
posted on 2/2/09 at 08:34 PM Reply With Quote
Am I correct in thinking that I can use an aftermarket steering wheel (Mountney) for SVA, provided that it is fitted to a COLLAPSIBLE boss? or will it still be considered as not 'Type approved' for the Sierra column?
Dangle_kt
posted on 2/2/09 at 08:38 PM Reply With Quote
the wheel needs to be padded and the collapsable boss needs to be fitted.
isn't easier to fit sierra wheel just for the test?
andrew.carwithen
posted on 2/2/09 at 08:54 PM Reply With Quote
Tried fitting my original Sierra wheel but it fouls on the column shrouds as I have adjusted the column length to suit the non-collapsible boss for my mountney wheel (which is shallower than the boss in the Sierra wheel) It also catches my knees big time (which could prove a major problem as I'll probably have to drive to the test centre some 40 miles away..
Reckon that fitting a non-collapsible boss would prove to be the easier option provided I can source one!
Dangle, weren't you trying to source a collapsible boss recently? Any joy? I've looked on ebay to no avail.
dogwood
posted on 2/2/09 at 09:38 PM Reply With Quote
As I said about a week ago.
The Gillingham centre will not accept aftermarket wheels.
I used a properly padded wheel with a collapsible boss.
It still failed because, as the examiner said.
it is a non type approved wheel on a type approved column.
I know some centres have passed them with aftermarket wheels.
I think I would fit your non standard one but take the Sierra one with you incase you need to change it.
FREE THE ROADSTER ONE…!!
