Kosmo
| posted on 9/2/09 at 09:47 PM |
Chassis No. and SVA
What are the SVA rules concerning the location of the chassis No. and does it have to be welded to the car if on a seperate plate or can it be riveted
eznfrank
| posted on 9/2/09 at 09:55 PM |
My letter from the DVLA says "The number should be stamped/embossed on the off side of the vehicle in a clearly visible and accessible position,
and by a method such as hammering or stamping, in such a way that it cannot deteriorate or be obliterated. It should also be stamped / embossed on a
plate which is attached to the vehicle".
Not from memory obviously!! I had my letter to hand because they rang me today to tell me the chassis number they allocated was wrong! Good job I aint
got it stamoed on yet then eh!!!
LBMEFM
| posted on 9/2/09 at 10:02 PM |
Surely you make up your own chassis number using 17 numbers/digits of your own choice. The plate cannot be rivited on because that can be easily
removed, it must be permantly welded or stamped on the chassis.
Humbug
| posted on 9/2/09 at 10:15 PM |
No, it varies from DVLA office to DVLA office. Best thing is always to contact them first and find out
James
| posted on 9/2/09 at 10:40 PM |
You need both.
James
- Muhammad Ali
ReMan
| posted on 9/2/09 at 11:11 PM |
Do whatever you want!
wicket
| posted on 9/2/09 at 11:15 PM |
I've got mine on once stamped on the chassis under the nose cone, fine for DVLA & SVA
nitram38
| posted on 10/2/09 at 08:56 AM |
Regarding Vin numbers.
You can make up a vin UP to 17 digits/letters, so it can be less than 17.
You must not use I, Q or the letter O.
As regards making your own, think about imported cars, they have a vin supplied in the country of origin and when sva'ed here, the dvla have to
accept that number so making your own should be no different.
Use a free vin checker (google) to test to see if your chosen vin exists. If not use and supply that one.
If you think that you might duplicate a vin, think again. The lottery is only 6 numbers and the odds of picking them is 14,000,000:1.
