spdpug98
| posted on 27/2/09 at 09:33 AM |
Reverse Box / Lever
Does the centre tunnel fall within the radius test area, I have a reverse box fitted and am unsure whether to fit the arm / lever through the tunnel
before the SVA or after.
My Blog: http://spdpug98.wordpress.com/
Mr Whippy
| posted on 27/2/09 at 09:36 AM |
think it does, but if you put a ball type knob on the end how could it fail, its just like the gearlever
spdpug98
| posted on 27/2/09 at 09:51 AM |
I didn't want a ball type top I wanted a 'T' shaped style lever, the main shaft of the lever will just be flat section ali so was
worried about the radius of the edges etc
Maybe I should just fit afterwards
designer
| posted on 27/2/09 at 10:04 AM |
Why not change the knob after?
spdpug98
| posted on 27/2/09 at 10:20 AM |
I could do, but not sure how I would fit a ball to a flat section of bar and then be able to remove afterwards
Mr Whippy
| posted on 27/2/09 at 10:40 AM |
I believe the hole has to be a different shape...
adithorp
| posted on 27/2/09 at 10:56 AM |
Internal radius rules apply. Use edge trim on the shaft of the lever and radius the ends of your T bar.
adrian
http://jpsc.org.uk/forum/
Richard Quinn
| posted on 27/2/09 at 11:35 AM |
If it's for the SVA test then why not just take the lever off for the test and put it back in after you've passed?
spdpug98
| posted on 27/2/09 at 05:12 PM |
I was going to leave it off but my mate who is doing all the little metal work bits was already planning on making it all rounded, so will possibly
fit it for SVA
Thanks for the advice
