| posted on 4/4/09 at 08:22 PM |
Do You Need...
1. A fuel gauge?
2. Rubber covers on suspension rose-joints on a full-bodied car?
blakep82
| posted on 4/4/09 at 08:24 PM |
no on both
only speedo is needed on S/IVA
the bodywork covers the suspension, in the same way 7's don't need rear shocks covered
[Edited on 4/4/09 by blakep82]
________________________
| posted on 4/4/09 at 08:27 PM |
Hoorah (and huzzah!).
Cheers buddy!
omega0684
| posted on 4/4/09 at 08:29 PM |
why would you not want a fuel gauge, you must have to be a jedi to feel when the tank is low!
blakep82
| posted on 4/4/09 at 08:31 PM |
at least thats the angle i'm going for since mine's full bodied, and i don't want to buy a fuel guage and sender
i'm considering a fluid level sensor for a low fuel light for mine. but no gauge as such
its true though, you don't need either. but with this monster engine (i think) you're fitting, a fuel guage might be a good idea
Miks15
Alot of bikes dont have them... i doesnt take long to get the feeling of how far youve travelled and how long ago you filled up last
owelly
| posted on 4/4/09 at 08:32 PM |
I know when my tank is getting low as the LP fuel pump buzzes like and excited bee.
http://www.ppcmag.co.uk
Paul TigerB6
| posted on 4/4/09 at 08:34 PM |
You can always fit a low fuel level warning light. Fuel resistant optical sensors are available from RS components for about £12 or so. Drill a hole
in the tank at an appropriate level and Bob's your mother's brother.
| posted on 4/4/09 at 08:35 PM |
Because I'm a Ninja (and they too can sense such things!).
Seriously though... I know I'll get 100 miles irrespective of how I drive it, so will just make sure that I fill up every time I reach that
mark. Did the same with an old bike I had which had a knackered gauge and it was no hardship!
blakep82
| posted on 4/4/09 at 08:48 PM |
exactly what i was thinking of doing. only thing is, what if you don't realise your warning light has blown?
Paul TigerB6
| posted on 4/4/09 at 08:56 PM |
Go for an LED - they dont blow very often.
Quick search - i think this is the part you'd be
wanting.
The pub's a calling so havent checked properly but think thats the right one
handyandy
| posted on 4/4/09 at 09:33 PM |
the same thing you do when the sender sticks, run out of fuel
happened on a tin top i once had, my mrs had been out in it, not fueled it up, i went out in it, gauge showed i had fuel but in reality the mrs
must,ve brought it home on vapour
andy
DIY Si
| posted on 4/4/09 at 09:40 PM |
Just do what I do and carry a cut down broom handle around with you as a dipstick. It gets some funny looks, but as it came from a knackered broom, it
was free. It even has a Biro line to show me what's full and what's half full! That or I just stop and chuck some fuel in every 100 miles
or so.
Sun Tzu, The Art of War
dinosaurjuice
| posted on 4/4/09 at 09:50 PM |
i dont have a fuel gauge on rocket yet.
i ran out of fuel last week
nearly wrecked a £600 common-rail pump.
should have known, hadnt filled it up since september
speedyxjs
| posted on 5/4/09 at 07:26 AM |
Cant you just fit an engine dipstick to the filler cap so you could check it the same way you check your engine oil?
Richard Quinn
| posted on 5/4/09 at 09:00 AM |
Isn't that what Ben's got in his and didn't
he run out of fuel on the way home from mine the other week?
Paul TigerB6
| posted on 5/4/09 at 10:15 AM |
quote: Originally posted by Richard QuinnIsn't that what Ben's got in his and didn't he run out of fuel on the way home from
Yeah - we need to check the wiring connections on it between the sensor and R1 bike clocks
NeilP
| posted on 5/4/09 at 10:36 AM |
IIRC you have to be able to demonstrate at SVA/IVA that the car is full of fuel as the full, wet weight is needed for the braking test - If you can
look in the hole and see this is fine...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
