cjtheman
| posted on 7/4/09 at 01:33 PM |
sva fail at cardiff today
some silly little bits to do a few sharp edges
has anybody got any idea's on speedo out
it reads 70 but actual speed was 84 mph
escort engine, gearbox ,and rear axle
tyres 185x70x13
self centring also needs looking at
noise 105db
but all in not a bad day out
cheers
colin
[Edited on 7/4/09 by cjtheman]
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
mad4x4
| posted on 7/4/09 at 01:58 PM |
Use a GPS to check it is correct before going back.....
What type for Speedo / Pickup you using .. mechanical / Electrical.
Magnets? Worm Gear? Digital? aftermarket or original Vehicle. Gauge is it New / Old etc?
Scot's do it better in Kilts.
wilkingj
Well thats not too bad. You now have a list of jobs to do. You should be able to see the light at the end of the tunnel.
Well done so far.
Best Regards
Geoff
http://www.v8viento.co.uk
jollygreengiant
| posted on 7/4/09 at 02:36 PM |
If its cable driven then you probably need a speedo driven gear (the removable one in the gearbox that the cable pushes into) with 2 teeth less than
the one that is in there.
Or send the speedo unit to a specialist and get them to re-calibrate it.
cjtheman
| posted on 7/4/09 at 04:19 PM |
good call jollygreengiant any idea where i can pick up one of these drives
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
fesycresy
| posted on 7/4/09 at 06:04 PM |
Can't believe how quickly you offered the tester a mint.
Ray will be shocked when I tell him
phil m
| posted on 7/4/09 at 06:15 PM |
Sorry to see a fail Colin
I'm back there thursday - noise!
Should be ok to sort out your problems -
Not sure you recieved my u2u.
Phil
aerosam
| posted on 7/4/09 at 08:36 PM |
Oh well Col doesn't sound too bad.
How long do you get to retest?
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
cjtheman
| posted on 7/4/09 at 09:43 PM |
hi phil
yes got your u2u
sam you get 6 months mate
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
