Dangle_kt
| posted on 13/4/09 at 07:03 PM |
fuel hose invoice - WANTED ;)
I had fuel hose fitted into my car (naval stuff apparently) but the invoice has gone missing proving its made for fuel.
I have the SVA in a few weeks and was hoping someone might have an invoice for grey rubber fuel hose rather than me have to buy a load and not fit it,
or rip it out unnessisarily.
Normally I'd just buy it, but lost my job last week and got no money coming in.
The fuel pump has just died on me, so have to buy that from my rapidly depleating funds, and can;t afford to buy a load of hose I don't actaully
need!
A colour scan would be great, as I'll print it off in colour.
r1_pete
| posted on 13/4/09 at 07:06 PM |
Can't help with the invoice, but isn't the hose itself marked up 'fuel' the stuff I bought recently is, about every 300mm.
Wheels244
| posted on 13/4/09 at 07:07 PM |
Hi Andy
What fuel pump is it ?
I might have one you can have .
Rob
Dangle_kt
| posted on 13/4/09 at 07:11 PM |
quote: Originally posted by Wheels244
Hi Andy
Rob
Its an R1 (carbed) fuel pump, but anything with same OD input/output considered
Dangle_kt
| posted on 13/4/09 at 07:12 PM |
unfortunatly nope! Thats the problem.
It is 100% for fuel, but is for a boat, so doesn't have the markings.
richardh
| posted on 13/4/09 at 07:14 PM |
i had fuel hose marked in german (pretty obviously saying fuel even for non-bilinguals but it failed on it. had to buy new hose that "clearly
states" it is for fuel.
some test stations seem to let an invoice fly but i had to bring in a sample of old german one but use new uk marked fuel line
best to let you know now save you maybe having to strip down later.......
Guinness
| posted on 13/4/09 at 07:24 PM |
How big is the hose?
I bought a length of fuel injection hose from Halfrauds on Saturday, but it's the wrong size.
So I have a 1 m length of 9.5mm internal diameter fuel hose, and a matching receipt you can have if it's any good to you?
Mike
jacko
| posted on 13/4/09 at 07:30 PM |
Mike
This site is fantastic made by people like this helping where they can
Guinness
| posted on 13/4/09 at 07:33 PM |
I also have a spare ZZR fuel pump.
I took it off earlier this year, after it refused to work.
I have just stripped it down, run a bit of emery paper around the terminals, and a shot of WD40 inside it, and flashed it across a battery.
It's working on demand at the moment.
Again, if you need / want it, it's your's.
No guarantee, warantee or money back on this one though!
Probably best to fit it somewhere accessible!
Let me know mate.
Mike
Wheels244
| posted on 13/4/09 at 08:08 PM |
Hi Andy
Rob
It's an electric Facet one - don't know if it's any use to you - but it's yours if you want it.
Rob
richardh
| posted on 13/4/09 at 08:20 PM |
i use a facet electric one
its a small square box in shape. seems to work ok for me.
this one is very similar to mine - if wheels 244 has this it will get you running
richardh
forgot linky
http://cgi.ebay.co.uk/Facet-Fuel-Pump-Brisca%2fKitcar%2fAutograss_W0QQitemZ280325815185QQcmdZViewItem
Wheels244
| posted on 13/4/09 at 08:31 PM |
Mines the round one
Bit like this one
http://cgi.ebay.co.uk/FACET-FUEL-PUMP_W0QQitemZ300307355516QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item300307355516&_trksid=p328
6.c0.m14&_trkparms=72%3A1689%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
richardh
| posted on 13/4/09 at 08:36 PM |
that's a v8 special. had to get a replacement for my landy a while back............
that will deliver fuel unough for the kit.
ps, i fitted a 1 way flow valve just past the pump so the pump did not tick over and pump too long to fill the pipe and filter before it could
start..............
Danozeman
| posted on 13/4/09 at 08:40 PM |
Could you not use the europa catalogue?
I have the reciept i think for the length of hose i used from europa. i can scan that for you if you like. U2U me if you need it as ill probably
forget to check here again.
Dan
cjtheman
| posted on 14/4/09 at 06:31 PM |
you have u2u
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
