Author: Subject: GUTTED!!!
Findlay234
posted on 24/4/09 at 08:34 AM Reply With Quote
GUTTED!!!
Didnt make my SVA yesterday...
Engine troubles started the day off. Bearing in mind that this is a self made loom and a personally rebuilt engine that hasnt missed a beat since i got it running on the second press of the start button around four years ago. I got straight into determining the problem and it turned out to be a loose pin in a connector. The connector was fastened tight but I think a pin must have been slightly out. It was now starting to come down to the wire for making my test.
So about an hour and a half later I got on the road and the car was a dream, couple of niggles and of course stopping every 20mins or so for the first part to check things over. Anyway by the time I had got half way I came to the crashing realisation I wasnt going to make the test. Called through and the VOSA switchboard couldnt get through to the sva station.....
Just didnt leave enough time, though the engine trouble didnt help at all. All in all its a bit gutting but it was a great drive, managed to cover about 65 miles before realising I wasnt going to make it!!
omega0684
posted on 24/4/09 at 08:38 AM Reply With Quote
absolutely gutted for you mate
COREdevelopments
posted on 24/4/09 at 08:39 AM Reply With Quote
oh no gutted for you mate. will you be able to re book?
rob
Steve Hignett
posted on 24/4/09 at 08:41 AM Reply With Quote
Gutted...
Findlay234
posted on 24/4/09 at 08:43 AM Reply With Quote
Some pics from that day!!
Before SVA
Before SVA
Before SVA 2
Before SVA 2
Before SVA 3
Before SVA 3
Ignore the crazy paint work, it will all be blue one day. Also note the deliberate SVA fail points..... Namely reflectors and centre mirror
[Edited on 24/4/09 by Findlay234]
gavin174
posted on 24/4/09 at 08:54 AM Reply With Quote
bad luck..
nice private plate thou..
looking at the pics is the rear fog 90 degrees to the road
Findlay234
posted on 24/4/09 at 09:03 AM Reply With Quote
Well couldnt get through to them yesterday a few times but will try today....
yeah add vertical fog to the reflectors and centre mirror.
posted on 24/4/09 at 09:29 AM Reply With Quote
AR^E and F***K - that is a real shame.
a prime exampe of Sod's law.
I had same - I fitted a maplins ignition thingy that did not skip a beat.
come SVA day, engine was misfiring big time, got maybe 500 m so turned round,
no idea what is was but figured that it was bestto iundo the last thing I did so I refitted original condener and wired out the maplins and it ran ok. (I later replaced the maplins unit and it hasbeen fine since - WTF??? - could have been carbs)
real panic, sweat pouring out type stuff but I had allowed well over an hour extra - as it was, I arrived with about 5 mins spare.
Findlay234
posted on 24/4/09 at 10:13 AM Reply With Quote
I had allowed two hours extra on top of the 4 hours I had allowed myself to get to the station but I dont think that was enough in the first place. well it might have been had I not stopped to check things werent falling off. nothing did, it was just my bloody paranoia.!!!!
Managed to get through to them today and they are going to try and sort one out for me next which is very nice of them. Dont hold much hope but at least they are trying....
posted on 24/4/09 at 10:21 AM Reply With Quote
I had the oil warning light come up on my first attempt - tried all sorts of things to fix it, but eventually had to abandon the test.
Found out later that I could have fixed it easily - a stuck oil pressure relief valve! The pump is easy to get at on the side of the x-flow, so it would have been a 5-minute job.
RickRick
posted on 24/4/09 at 10:27 AM Reply With Quote
i have also sufferd at the hands of sods law, set off in plenty of time for my test with the car on trailer, trailer tyre blew out on the motorway, it's a borrowed trailer, and the spare was also missing. pulling it with a pug, 108 pcd, trailer 100 pcd so couldn't even bodge on the car spare
bob
posted on 24/4/09 at 10:42 AM Reply With Quote
Sorry to hear this fin, at least the car is running now and the 65 miles you covered is a good shakedown.
Where was your test.... Yeading or mitcham ?
Findlay234
posted on 24/4/09 at 12:23 PM Reply With Quote
wasnt either, had to get over to gillingham, hence I wouldnt have made it in the four hours I gave myself. Didnt want to hit the motorway for its first drive. May well do next time.
posted on 24/4/09 at 12:25 PM Reply With Quote
You need a grill as well to cover rthe contactable point inside..
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 24/4/09 at 12:59 PM Reply With Quote
Also nut covers on some of your front wishbones? not clear from the photo though so i might be wrong.
Findlay234
posted on 24/4/09 at 01:37 PM Reply With Quote
ive got the grill just wasnt on for the photo and it does have nut covers.
Talked to gillingham and theyve got no room for an sva so i either have to phone around for any cancelations or go through IVA.....
anyone know anyone whos cancelling on monday or tuesday?
