<<  1    2  >>
Author: Subject: Absolute effing disaster :(
james h
posted on 27/4/09 at 08:43 AM Reply With Quote
I knew I wasn't going to pass the SVA today, but at least my engine was running... or so I thought, so I could at least not get a refusal.
Started it today, and after five minutes half the sparkplug came out . The other half is in the engine still.
Now I have no chance to get it ready for 1pm today.
Dangle_kt
posted on 27/4/09 at 08:45 AM Reply With Quote
o no! Thats aweful news!
Is there no way you could do the test running on three?
nitram38
posted on 27/4/09 at 08:48 AM Reply With Quote
Is it just the threaded part?
Can you use a mig welder to build a blob on top and then weld a bar to it?
The extra heat will also help getting it out.
Then just put a new plug in
Howlor
posted on 27/4/09 at 09:03 AM Reply With Quote
Is it just the insulator that has snapped or have you lost the hex top as well?
I 2nd the welder trick. Has worked for me a few times.
[Edited on 27/4/09 by Howlor]
Mr Whippy
posted on 27/4/09 at 09:18 AM Reply With Quote
given that the plug is recessed into the head, then personally if you can still see the center electrode. I'd wrap the end of the HT lead up in rubber hose and insulation tape (till it’s almost the same diameter as the hole in the head and ram it right down there against the end of the spark plug. If you've done it carefully the spark will jump quite happily to the plug and still run the cylinder for the test. Might look a tad odd but it should get you running, you can remove the plug remains later.
[Edited on 27/4/09 by Mr Whippy]
james h
posted on 27/4/09 at 09:22 AM Reply With Quote
The centre section of the plug has come out, and the tip has completely burnt out, but the threaded part that goes into the head is still in there.
No welder
We are taking the car to the SVA centre anyway, see what the examiner says.
Looking bad though
posted on 27/4/09 at 09:31 AM Reply With Quote
ooh, must have been typing whe you posted.
so where is the hex part - in or out?
Mr Whippy
posted on 27/4/09 at 09:36 AM Reply With Quote
Oh I think he's saying the threaded ring is all that’s left in the head
You need a big easy out then that will fit inside the ring, might have been due to corrosion of the steel and alloy head due to no copper slip being used on the thread
problem is, if the thread is really corroded then it might be destroyed in the process meaning a new thread insert would be needed and the head being removed
richardh
posted on 27/4/09 at 09:37 AM Reply With Quote
cant you take it to any place with a welder on the way and quickly get someone to weld it and remove it as per the guys above idea?
most places would be happy to help a kit car
Time for a change!
Mr Whippy
posted on 27/4/09 at 09:50 AM Reply With Quote
guess that'll make sense, I didn't thing plugs could break in that fashion
how can that happen?
did the piston push the innards out?!?!!
look at the top of the thread and you can see the thinnest section is there with a bit meaty bit above for the hex, practically designed to snap there
With modern alloy heads this is quite common, didn't tend to happen on cast iron head. Thats one of the reasons its so important to grease the thread
james h
posted on 27/4/09 at 09:51 AM Reply With Quote
Sorted!!!! (many thanks to Mk II)
The threaded part was all that was left in. In effect, you could see into the cylinder.
We put a screwdriver and tapped it into the hole gently, and just managed to turn the threaded part out. A bit of blu-tac and a wire got it and the washer out.
We replaced the spark plug, lets hope its not something more serious in the engine which has caused this (it was a new sparkplug too)
James
nitram38
posted on 27/4/09 at 09:52 AM Reply With Quote
Well Done!!!!
Mr Whippy
posted on 27/4/09 at 09:59 AM Reply With Quote
nice one
jabbahutt
posted on 27/4/09 at 10:01 AM Reply With Quote
fantastic news, read your post this morning and was gutted for you. good luck with the SVA test.
dhutch
posted on 27/4/09 at 10:04 AM Reply With Quote
Spot on!
Had simular on a kart engine, took it out with a tread extractor bound onto the wrong end of 3/8th extention bar.
- Athough we lost half an hour before remembering about the electrode thats bend round at the end and had to be tapped stright with a screwdriver before the extractor would go in.
Daniel
Howlor
posted on 27/4/09 at 10:19 AM Reply With Quote
I think a cleansing lager may be required later.
richardh
posted on 27/4/09 at 10:25 AM Reply With Quote
well done and good luck today
Time for a change!
Dangle_kt
posted on 27/4/09 at 10:28 AM Reply With Quote
I love it when a plan comes together!
Excellent stuff
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 27/4/09 at 10:37 AM Reply With Quote
did you grease the thread of the new plug
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 27/4/09 at 10:52 AM Reply With Quote
tomprescott
posted on 27/4/09 at 11:30 AM Reply With Quote
Well done, hope you get on well with SVA, good luck!
P.s. Am I the only person who thinks that welding onto the sparkplug in a fitted engine sounds like a good way to cause an explosion?
[Edited on 27/4/09 by tomprescott]
Mr Whippy
posted on 27/4/09 at 12:33 PM Reply With Quote
its ok as the amount of fuel and air in the cylinder is tiny and very quickly burns off if ignited with a small PHUT!
stuart_g
posted on 27/4/09 at 01:55 PM Reply With Quote
I don't think you would get a welder down the recess on the head on an R1 to where the part of the plug would have been, they are quite a way down. If you could get a welder down there you would not be able to see what you were doing.
Glad you got it sorted and good luck.
posted on 27/4/09 at 02:38 PM Reply With Quote
.... maybe worth checking the other plugs too ...
james h
posted on 27/4/09 at 05:49 PM Reply With Quote
Phew! Engine started up fine when I got to the test centre.
The list of items to remedy is as long as War and Peace, but at least its something to work on for 6 months!
Thanks for all your suggestions and encouragement
And I have never been so happy to fail!
James
<<  1    2  >>
