Author: Subject: What should Emissions be??
Krismc
posted on 6/5/09 at 08:36 PM Reply With Quote
Can anyone confirm a for a new plate a 2.0 Zetec running....
Fast Idle
Co 0.006 and 6PPM Hc
and
Idle
Co 0.027 and 19PPM Hc
Will this pass? Think im inside the limits enough??
I was confident they are, but the guy who picked my car up from engine tuners tonight seemed to think they where high.
belgian2b
posted on 6/5/09 at 09:01 PM Reply With Quote
For an engine after 1995 :
Iddle : CO under 0.5 %
Fast iddle ( 2500 -3000 RPM)
CO under 0.3%
HC under 200 ppm
Lambda : from 0.97 to 1.03
Gerardo
bassett
posted on 6/5/09 at 09:12 PM Reply With Quote
Looks like your easily within parameters but whats your fast idle lamda?
[Edited on 6/5/09 by bassett]
adithorp
posted on 7/5/09 at 07:22 AM Reply With Quote
"...the guy who picked my car up from engine tuners tonight seemed to think they where high. "
Based on what? Just a guess?
The readings you've given are well within the limits but Lambda reading is needed as well before we can say.
adrian
http://jpsc.org.uk/forum/
Krismc
posted on 7/5/09 at 04:11 PM Reply With Quote
Ive got a 2 print outs which the guy looked and said it was high. but mybees he is wrong.
I didnt get a lambda reading as i havent got one fitted, the engine tuner said the megasquirt wouldnt run with it and he could set it up better with out it.
So i spent £176 on a nice lamda and guage for nothing- i asked him 3 times to get it working with it, but he didnt.
belgian2b
posted on 9/5/09 at 09:13 PM Reply With Quote
Hello,
i don't know about Megasquirt, but to pass SVA the tuner needs to check the Lambda value.
You need to have both parameters right to pass SVA.
Gerardo
posted on 10/5/09 at 06:07 AM Reply With Quote
The Lambda reading you need has nothing to do with whether or not a Lambda sensor is fitted although you will probably need one to get within the required limits. The reading is taken from the exhaust gases by the emission tester and will be printed out on the results sheet.
Krismc
posted on 10/5/09 at 02:33 PM Reply With Quote
Ah, i have a lamda value of 1.071 fast idel and 1.852 on idle!
adithorp
posted on 10/5/09 at 07:29 PM Reply With Quote
For the test the lambda at fast idle must be between 0.97 and 1.03. So yes it will fail. 1.07 is too weak or there's an air leak on the exhaust.
Did your tuner know that it was to meet these regs that you were having it set?They're the same as MOT requirements so he should be familiar with them.
adrian
posted on 11/5/09 at 07:23 PM Reply With Quote
Even a very small leak in the exhaust system will affect the lambda reading. As said it looks as if the engine is running too weak though.
