nstrug
| posted on 31/5/09 at 03:52 PM |
SVA retest tomorrow...
Well, I'm prepared as I ever will be I suppose. Just worried that it's still not quiet enough and the brakes are still horribly squishy -
it only failed on balance last time rather than efficiency so I have unpinned the balance bar and will take a drill and repin after the test.
I'm just hoping that they will firm up a bit as they bed in.
If I lose out again on the noise test I'll really be all out of ideas
Nick
speedyxjs
| posted on 31/5/09 at 03:54 PM |
Good Luck
madteg
| posted on 31/5/09 at 04:05 PM |
Good luck..........
Dangle_kt
| posted on 31/5/09 at 04:09 PM |
All the best!
What steps have you taken to reduce noise?
Mine was 104dB so I'll read your reply with avid interest!
[Edited on 31/5/09 by Dangle_kt]
Flamez
| posted on 31/5/09 at 04:10 PM |
box spanner wrapped in wire wool shoved up the exhaust outlet..
my build mac1motorsports
twybrow
| posted on 31/5/09 at 04:19 PM |
Good luck - its worth it!
Stuart_B
| posted on 31/5/09 at 05:24 PM |
good luck
stevegough
| posted on 31/5/09 at 08:18 PM |
Yes, good luck and we're all rooting for you...
Steve.
may be a bit late but there is a guy on here (chris_smith) offering an 86db silencer for SVA...(see for sale ads) .. but I suppose your mind had
already been down that path?
[Edited on 31/5/09 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
nstrug
| posted on 31/5/09 at 09:21 PM |
Not easy to swap silencers as the Dax silencer has the cat and 4-1 collector built into it.
To reduce the sound I lined the engine compartment with 20mm sound deadening, added sound deadening pads to all the ally panels in the cockpit, put a
decibel insert in the silencer, added a cone baffle to the tailpipe and filled the tailpipe with wirewool.
I think the real problem with the Dax exhaust is the 2.5" tailpipe is like a megaphone. The combination of the decibel insert and the cone
baffle has quietened it down considerably but as I failed at 107dB last time I'm going to need every bit of it.
Nick
nstrug
| posted on 1/6/09 at 06:19 PM |
Well, passed on everything but o/s mirror. My new mirrors passed the mirror test fine, however they just miss the minimum vertical dimension by 5mm.
Kind of ironic that the old mirrors easily passed the minimum dimensions but failed the actual mirror test, now I have some that pass the test, they
fail on dimensions
Anyway, sound came in at 100.2dB so that was good. He said it was actually 102dB in the 6k range but was much quieter at 7800rpm where he tested
me.
Brake balance passed, speedo passed thanks to the firmware update from ETB, the extra steering column support he asked me to put in passed, everything
else was great.
So now I need to find a mirror, hopefully with an M8 stem, that passes the minimum dimensions.
Nick
stevegough
| posted on 1/6/09 at 08:59 PM |
Well done - is it going to be 3rd time lucky?
Just be thankful you are SVA retesting - £30 a shot? Because IVA retesting is £90 a pop.
I think the Idea is to get the amateur builders to dot all the i's and cross all the t's precisely and get it 'right first
time' otherwise its going to cost us dear! (as well as being another 'hidden tax' )
Sorry, I'm still seething!
Get you mirrors sorted and get out on the road and enjoy!
Steve.
Luego Locost C20XE.
