albertz
| posted on 7/3/04 at 06:52 PM |
Private number plates???
Does anyone know what the law is regarding fitting private plates to a kitcar.
It looks as though my car will be a 'Q' plate, if i ever get that far. I have a private plate on retention, can i register the car with
the Q plate and then put on the private number once on the road?
Probably not.............that would be too easy!
flak monkey
| posted on 7/3/04 at 06:58 PM |
Once a Q always a Q unfortunately, so you cant put another plate on it.
If its not a Q then you cant put a plate on that would make the car newer than it is....
If its a D reg to start with, you cant put any plate later than a D on. Only earlier.
Probably doesnt make sense...
Sera
http://www.motosera.com
Mk-Ninja
| posted on 7/3/04 at 07:00 PM |
Sorry. If you get a Q plate it has to stay as a Q. If you want a privat plate on then you need to get an age related plate first.
HTH Gordon
I'm sure I've got one, just don't know where I've put it
theconrodkid
| posted on 7/3/04 at 07:22 PM |
never wanting to miss a trick the dvla are going to do q plates with interesting letters/numbers
who cares who wins
pass the pork pies
albertz
| posted on 7/3/04 at 07:30 PM |
Will i get a Q reg?
I am building a Toyota 4AGE powered Locost with a Sierra gearbox, Escort back axle and prop and Cortina front hubs.
unfortunately i dont have a V5 for any of the above, although i have the complete Corolla.
Do i have any options/possibilities, or is it a definite Q plate?
Are there any tricks out there to get by the problem?
Surely most Locosts must be Q plate, if not why?
Mk-Ninja
| posted on 7/3/04 at 07:41 PM |
You definitely need a V5 or youve no chance. If you could get a V5 then you have a chance, you need 2 major components from Engine, Steering assy,
Axles (both), Transmission, Suspension (Front & Back). Therefore if you can get a V5 you could change (theroretical) say the engine to the 4age
before you use it as the donor.
theconrodkid
| posted on 7/3/04 at 07:58 PM |
i had everything off a mk2 escort inc paperwork with seirra box n cortina uprights and still got a Q
who cares who wins
pass the pork pies
Mk-Ninja
| posted on 7/3/04 at 09:16 PM |
You was robbed
albertz
| posted on 7/3/04 at 09:18 PM |
It is looking like a Q plate for me then.
What is the problem with that? is it just the stigma attached?
How does the registration mark affect the value? not that i can really see me selling my car.
What other disadvantages are there to having a Q plate?
highspeeddirt
| posted on 8/3/04 at 01:13 AM |
I can think of one big advantage to a Q plate, no emissions test come MOT time
