Author: Subject: IVA front view
greed1
posted on 1/11/09 at 10:27 PM Reply With Quote
IVA front view
will these bike carbs and filter be a problem come the IVA
i am planning to cover the sharp edges with a bulge and just leave the foam will it get through the forward vision part of the test
thanks
Drive it stright sideways
Mr Whippy
posted on 2/11/09 at 08:52 AM Reply With Quote
hmm doubt it, why not "for the test only" just fit some gauze mesh over the inlets and leave the foam filter at home. No point in making life hard for yourself when you don't really need too. If you did that then you'd only need a very small temporary bulge.
Findlay234
posted on 2/11/09 at 09:09 AM Reply With Quote
I have the same issue a plenum that sticks up to poke through the bonnet by a centimetre or so and was thinking about a mesh to cover it for IVA.... What are the rules about sharp edges and mesh. Ive got expanded mesh from B&Q with 5mm diamond shaped holes... when you rub your hand over it you wouldnt call it sharp but each wire would be considered sharp on its own.
A1
posted on 2/11/09 at 11:55 AM Reply With Quote
theres a front vision part of the test now?!
Mr Whippy
posted on 2/11/09 at 03:40 PM Reply With Quote
there always has been, its in the manual
greed1
posted on 2/11/09 at 07:58 PM Reply With Quote
wire mesh sounds a good idea (so long as the mesh is small enough) that way i wouldnt need to buy some gauze mesh to go over the inlet just surround the whole thing in mesh wouldnt then need to make a bulge out of fibre glass
thanks for the ideas
still got to cut a hole in the bonnet
is there any way to get around that lol
if not how do i mark were i cat the bonnet
[Edited on 2/11/09 by greed1]
