Author: Subject: 19 mm radius
greed1
posted on 10/11/09 at 06:35 PM Reply With Quote
19 mm radius
how do you measure the 19mm radius on a hard dash
thanks
Drive it stright sideways
afj
posted on 10/11/09 at 06:38 PM Reply With Quote
draw a 38mm circle and cut out then cut in half??? is that right
or 19mm
[Edited on 10/11/09 by afj]
eerrrrrrrrrrrrrrrr
designer
posted on 10/11/09 at 06:46 PM Reply With Quote
Draw a 38mm diameter, 19mm radius, circle and cut into four equal pieces,
Radius is measured by a quadrant.
greed1
posted on 10/11/09 at 06:52 PM Reply With Quote
once i have the quadrants how do i then measure something like this
cheers
MikeR
posted on 10/11/09 at 07:15 PM Reply With Quote
get a bit of wood, drill a 38 mill hole. Throw the middle bit you've just drilled away. Cut the wood you're left with (which has the hole in it) into 4 equal parts. See if the radius of the bit matches the 1/4 you've got.
hicost blade
posted on 10/11/09 at 07:32 PM Reply With Quote
I may have a 38mm hole saw in my garage, if not their should be one at work
1 1/2" isnt it?
Nice dash BTW
[Edited on 10/11/09 by hicost blade]
greed1
posted on 10/11/09 at 07:58 PM Reply With Quote
good thinking batman mike now why didnt i think of that
tomorrow it will be a nice dash as will be in my hands
dave i think i have the right size hole saw and from the pics it plenty big enough
i just wanted to make sure before i bought something else that wouldnt go through the IVA like the seats and the fuel tank
thanks graham
[Edited on 10/11/09 by greed1]
ReMan
posted on 10/11/09 at 11:03 PM Reply With Quote
Nice dash, I lke them, no good for bike clocks though
But I dont think it will pass S/IVA
greed1
posted on 11/11/09 at 08:01 AM Reply With Quote
why that ????
minitici
posted on 11/11/09 at 10:37 AM Reply With Quote
How far does the 19mm radius have to go round the bottom edge of the instrument/dash panel?
Is it checked going forward or is it also checked coming back towards the driver?
ReMan
posted on 13/11/09 at 07:36 AM Reply With Quote
Originally posted by greed1
why that ????
Sorry,because it don't look like a 19rad.I hope I am wrong?
The Black Flash
posted on 18/11/09 at 10:39 PM Reply With Quote
I believe it needs to have a "deformable" (i.e. covered foam) covering for IVA as well
Staple balls
posted on 18/11/09 at 11:02 PM Reply With Quote
I thought it was 19mm radius or Foam covered?
greed1
posted on 18/11/09 at 11:23 PM Reply With Quote
19mm radius if solid
and 5mm if it foamed (not quite sure its 5mm but some will correct me)
the dash in the pic does seam to have all the correct radii to get through the IVA but the prof is in the eating
i mean testing
The Black Flash
posted on 20/11/09 at 03:39 PM Reply With Quote
You're quite right; 19 if solid, 5 if foamy
"7. The instrument panel lower edge within the “specified zone” must have a radius of curvature not less than 19mm or 5mm and covered with a non-rigid material. Except where an adaptation for a disabled person makes it impossible to comply. (see note 7) "
