chris.chatland
| posted on 10/4/04 at 06:33 PM |
Harness Mounting height
Ok guy's.
The SVA manual say's that the minimum hieght for Harness mounting above seat is 450mm + 53mm for the know block measure.
Can it be higher and is it better to be higher as i'm welding in a cross tube with mounts to the roll bar?
MikeR
| posted on 10/4/04 at 10:05 PM |
The SVA manual details the MINIMUM height. Higher is better - especially if you're tall as it stops your spine being broken in a bad crash.
Fifer
| posted on 10/4/04 at 11:09 PM |
Just watch the extra height if your belts go through seat holes, if the belt passes through these and then goes way above these the seat strenght
comes into play !
But, as above, heigher is better.
chris.chatland
posted on 11/4/04 at 08:10 PM |
Cheers guy's !!!
