FrankP
| posted on 20/5/10 at 05:45 PM |
So Near yet So far IVA Fail
Well I did my IVA retest at Nottingham.
Everything wa sok except emissions..
To be fair they gave plenty of time po try and get it and when we thought we had it the car dveloped a misfire - somebody suggested a plug had over
heated and stopped after an hour at 3000 rpm.
When I got home it was running fine so it looks like a heat related issue...
The readings were
HC 40
CO 0.0
Lambada 1.3
So it looks like it was too lean. I need to get it on an emissions machine to finish off the tune..... Anyone know a mobile mechanic who could
help??
Anyways almost there........
Frank
speedyxjs
| posted on 20/5/10 at 05:52 PM |
THats probably the best fail i have seen for ages. Not too long and you'll be on the road!
cd.thomson
| posted on 20/5/10 at 05:54 PM |
comeon, its a retest speedy! cant compare that with my two and a half page list
nice one frank, see you around an about in a couple of weeks when im on the road too
[Edited on 20/5/10 by cd.thomson]
Craig
speedyxjs
| posted on 20/5/10 at 06:28 PM |
I have got to read things a bit better. I misread a post this morning too
adithorp
| posted on 20/5/10 at 07:39 PM |
It could just be too weak, however an air leak on the exhaust will also cause a high lambda reading. Make sure there's no leaks on any joints or
silencer seams. Clear silicone sealant will seal then. Don't worry it will take the temp'.
I had trouble controling the emmisions on my SVA as the temps got high. I wired my fan to run constant for my retest.
adrian
http://jpsc.org.uk/forum/
