40inches
| posted on 7/6/10 at 08:13 PM |
Another IVA change
IVA change to radius on suspension,Exterior Projections 16, Figure 5
  IVA change
1st image:Simplified representation of front suspension of frame based vehicle with exposed suspension
2nd image:Contactable exterior surfaces of functional steering and suspension components are assessed against relevant radius requirements.
3rd image:Items within the volume enclosed by suspension components are exempt from exterior projection assessment.
Mal
| posted on 7/6/10 at 08:20 PM |
For a change it makes things easier!
eznfrank
| posted on 7/6/10 at 08:31 PM |
I've just had a few days off work and spent alot of that messing around making the front end IVA friendly!!!!
eznfrank
| posted on 7/6/10 at 08:33 PM |
When does this come into force?
tegwin
| posted on 7/6/10 at 08:37 PM |
I am actually quite scared.... some sort of logic appears to have been applied....
www.verticalhorizonsmedia.tv
Michael
| posted on 7/6/10 at 08:38 PM |
I saw that in the updated IVA Manual two and thought does that mean no more covering suspension items.
Then again i was going to do the IVA book and chuck pictures of mine up to get opinions as my indicators come halfway across from suspension.
40inches
| posted on 7/6/10 at 08:52 PM |
In force now
| posted on 7/6/10 at 09:13 PM |
About time too! Always thought that was just plain stupid!
ashg
| posted on 7/6/10 at 09:56 PM |
i believe they have been applying it for quite a while prior to the new manual release coming out
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Nash
| posted on 7/6/10 at 10:49 PM |
no they haven't. I had to radius my shock absorber bottoms and spring "C" ring two weeks ago for sharp edges!
I'm now hacked off as reshaping the shockers is not a pleasent thing to do and difficult to maintain the asthetic of the units !
...........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
40inches
| posted on 8/6/10 at 07:13 AM |
...........Neil
That sucks! It became live on the 24th May
alistairolsen
| posted on 8/6/10 at 08:48 AM |
So that means no more radiusing shocks and springs and rubber boots, but presumerably still means that frame brackets have to be protected, along with
the outer end of the steering arm and ball joint, any camber adjustment in the top wishbone?
I still stand by the fat that if you’e hit by a wishbone you have bigger problems than a ball joint with no heat shrink over it!
My Build Thread
skinned knuckles
| posted on 8/6/10 at 10:42 AM |
maybe but its still a step in the right direction
A man isn't complete until he's married, then he's finished
Neville Jones
| posted on 8/6/10 at 06:03 PM |
Most stupid thing with the front end is, checking the brake calipers with the radius thing. You've got enormous problems as a pedestrian, if the
brake caliper radius is affecting you.
40inches
| posted on 8/6/10 at 09:07 PM |
16 Exterior Projections
Method of Inspection
"The area within wheels and tyres is not considered to be an external surface."
Neville Jones
| posted on 10/6/10 at 09:16 AM |
It is if the caliper protrudes outside of the wheel/tyre profile.
A straight edge, held vertically against the tyre, will show what counts and what doesn't. As the testing officer told me, anyhow.
Nev.
