cps13
| posted on 6/12/10 at 01:11 PM |
Pedal box fitting & fuel pipe type
hi,
i am currently building a locost style kit and have a couple of IVA questions.
1. I have a floor mounted pedal box for brake & clutch. Is it ok to bolt this to the floor as I want to be able to easily remove it if needs be.
Or does it need to be permanently fixed?
2. The fuel pipes I have running under the car are steel pipes. One of the pipes is about 4 inches too short to run the length of the car. Would it be
deemed unsafe if I put steel braided rubber hose for that last 4 inches or do i need a whole new pipe?
Thanks all.
redeye
| posted on 6/12/10 at 01:21 PM |
Hi
My pedal box is floor mounted and is bolted in so can be removed if need be,
Shouldnt be a problem for Iva
Not sure about the brake pipe tho
mattyc
| posted on 6/12/10 at 02:03 PM |
"The fuel pipesrunning under the car are steel pipes" I understood this was a no no. worth checking tho. Most people run fuel pipes down
one side of the tranmission tunnel.
cps13
| posted on 6/12/10 at 03:01 PM |
i'm following the westfield manual, albeit about 18 months old, so unless it has been updated since i thought it would be ok.
Anybody know any different??
