Author: Subject: Fuel Line P-Clips
James
posted on 21/6/04 at 08:42 PM Reply With Quote
Fuel Line P-Clips
Could someone remind me of the maximum clip spacing for fuel lines please?
Pretty sure it was 300mm same as brake lines but can't get to SVA manual right now and I want to drill them now.
James
Viper
posted on 21/6/04 at 08:50 PM Reply With Quote
can't see anything in the book about spacing, any ideas what its under?
for the record i spaced mine something like every 75mm if memory serves me..
Mk-Ninja
posted on 21/6/04 at 08:58 PM Reply With Quote
When I had my SVA they said they wanted clips no more than 200mm apart and in general 150mm. But I think it depends on the tester you get, like alot of this stuff.
Gordon
I'm sure I've got one, just don't know where I've put it
posted on 21/6/04 at 09:23 PM Reply With Quote
god damn it, everything of mine is done to 300mm, if they fail me i'll kick his knackers out of his nose...
for the record, is the loom meant to be clipped every 300 or less?!
James
posted on 21/6/04 at 09:33 PM Reply With Quote
Oh blinkin 'eck I was sure the brakes were 300mm- I thought I was being too generous in what I've just done which is mostly 150mm but up to 250mm where objects dictated.
The bloody chassis will fall apart if I drill many more!
Also, Tifosi only sent me 14clips with my fuel line kit, at 150mm I can only clip 2.4m worth of fuel line!
James
bob
posted on 21/6/04 at 09:46 PM Reply With Quote
my SVA examiner mentioned something about no less than 9"s apart,300 mm is nearly 12".
Must admit it depends on where you go probably.
Fozzie
posted on 21/6/04 at 09:47 PM Reply With Quote
James,gets confusing doesn't it?
Best to work at 300mm or less (12inches) in old money! lol
Thats for fuel, brakes and wiring.
HTH
fozzie
James
posted on 21/6/04 at 10:39 PM Reply With Quote
Trials and Tribulations!
Ok, well added a bunch of brake (3/16th) P-clips- easy as I have a bag of 100.
Anybody got a few 3/8th clips they would sell me (or better still swap for an appropriate amount of 3/16th or 5/16th) please?
I'm after about 10 but can probably get away with a couple less if that's all you can spare.
Thanks,
James
EDIT: As a last resort, can anyone remind me who the company is that sells them at shows? The do them in blue&white bags of 50/100 or so. The Tifosi ones are little pricey!
[Edited on 21/6/04 by James]
ned
posted on 22/6/04 at 08:38 AM Reply With Quote
James,
don't forget your chassis is longer, so the kit you bought might have had enough for a book chassis..
Ned.
beware, I've got yellow skin
jimgiblett
posted on 22/6/04 at 09:17 AM Reply With Quote
Hi James
I got my rubber lined s/steel p clips from
Beal (UK) Ltd
Albion Mills, Church Street
Morley, Leeds
LS27 8LY
Tel: 0113 253 8888
Fax: 0113 253 0223
www.beal.org.uk
This was alot cheaper than the shows.
I'll see if I have any 10mm (3/8ths = 9.525mm) left over from my build. IIRC I used most of em.
Jim
[Edited on 22/6/04 by jimgiblett]
Mk-Ninja
posted on 22/6/04 at 09:46 AM Reply With Quote
I should have a few James. If I find them Ill post them to you, think I should have your address somewhere.
Gordon
wicket
posted on 22/6/04 at 12:11 PM Reply With Quote
Just spoken to Bob Taylor on the SVA Tech helpdesk on the subject of fuel line clip fixing distance and he comfirmed that it does not actually specify the distance they should be apart. He suggests 300mm, if its OK for wiring then it should be OK for the fuel line as well. He also said if the test engineer asks for them to be closer together challenge him & ask where he gets his figure from.
posted on 22/6/04 at 02:30 PM Reply With Quote
nice one wicket, thanks for finding out!
ned
posted on 22/6/04 at 02:56 PM Reply With Quote
Gordon,
If you find them before friday bring em down to goodwood, i live only a mile or so from james so can pop round and pass em on..
Ned.
Mk-Ninja
posted on 22/6/04 at 03:53 PM Reply With Quote
Thanks for the offer Ned but I put what I had in the post before lunch. There was only 2 Metal/Rubber ones and a hand full of plastic.
Gordon
ned
posted on 22/6/04 at 04:11 PM Reply With Quote
blimey gordon that was quick! what a " true gent"
Ned.
James
posted on 22/6/04 at 04:57 PM Reply With Quote
Gordon
Just read this Gordon- thankyou very much you're a star!
What do I owe you?
Thanks,
James
Mk-Ninja
posted on 22/6/04 at 05:20 PM Reply With Quote
No problem just a pity I couldnt find any more, if I do Ill bring them down to goodwood but dont get your hopes up.
James
posted on 25/6/04 at 12:40 PM Reply With Quote
Recieved them last night.
I'm off work today so as soon as I drag myself away from this bloody forum I'll get on with attaching them to the car!
Thankyou very much for sending them!
James
posted on 25/6/04 at 01:49 PM Reply With Quote
if you are still short i should be able to dig some out too, i got many of the brake pipe clips and some big ones too.
