Berwyn
| posted on 9/7/04 at 10:29 AM |
Fireblade emmisions
Failed the MOT yesterday on emmisions and no number plate
Number plate i can sort by getting the garage to read the f'ing manual or calling VOSA, but the emissions thing could be a problem. The engine
is a blade 1993 , so needs to meet 3.5% CO and 12,000 hydrocarbons. It is currently running at 6% . Is this going to be tricky or is there a simple
screw to wind in on the carbs???
24 hours in a day, 24 beers in a case. Coincidence? I think not
| posted on 9/7/04 at 11:30 AM |
Berwyn,
There is no simple adjustment screw on carbs. If I were you, I wouldn't bother worrying about it. When we had ours MOT tested (1995 RRS) they
said they had no emmissions criteria to measure it against on their computer.
It passed emmissions at SVA with flying colours.
As everything else seems OK, I'd go for SVA and hope it passes that.
alister667
| posted on 9/7/04 at 11:54 AM |
Hmmm think you were stuffed twice there. Certainly in Northern Ireland - and I'm *pretty* sure it's the same for the rest of the UK the
emmissions test for any kit car is the visible smoke test only.
I.e. if the engine isn't producing excessive smoke then it's deemed a pass.
Certainly that's what my MOT (done at a government run test centre) consisted off. I even rang before hand to confrim this was the case - and
had that explained to me.
I've seen other folks from the mainland mention the visible smoke test / MOT thing before as well on here.
Sounds like you were swizzled out of a pass!
Better luck next time
Ali
http://members.lycos.co.uk/alister667/
Jon Ison
| posted on 9/7/04 at 11:59 AM |
I think A is right, smoke test only int it on Kit cars
Berwyn
| posted on 9/7/04 at 12:13 PM |
Argh!
I called VOSA and they said that it only needs a visual smoke test and that the garage should have written NON DISPLAYED for the reg plate.
I called Cardiff SVA station and they said that for that year of engine it needs to pass the 3.5%CO & 12,000 HC test, but he agreed with the NON
DISPLAYED part. I am waiting for my SVA date from Bristol, so i have called them, and they said, Ooh, we'll call you back........
I'm waiting
But thanks for the info so far guys.
[Edited on 9/7/04 by Berwyn]
Jon Ison
| posted on 9/7/04 at 12:15 PM |
at least you know now, good luck with the SVA, you'l get thru it i'm sure...
| posted on 9/7/04 at 12:21 PM |
Forget the MOT. Good luck with SVA.
Berwyn
| posted on 9/7/04 at 03:46 PM |
Bristol VRO got back to me and implied there has been a recent change ! It does need a CO test, and must be below 3.5, but they dont need to do a
hydrocarbon test.
| posted on 9/7/04 at 05:48 PM |
Berwyn
Our standard engine (dyno'd) obviously passed the SVA with this, no adjustments were necessary! It's not a recent change at all for the
3.5 it's been this since Jan 2004 IIRC
Just make sure it's warm and all potential exhaust 'sucks' are sealed. Good luck!
[Edited on 9-7-04 by Hellfire]
Berwyn
| posted on 9/7/04 at 07:18 PM |
Thanks for that HellFire.
I hope mine goes through too
I'll let you know.
paulbeyer
| posted on 9/7/04 at 08:32 PM |
Berwyn,
If you want someone to come along for your SVA test I'm happy to help out.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Lightning
| posted on 9/7/04 at 08:52 PM |
Mine failed on tick over , but passed when taken to apparently allowable 2000revs.
Off of idle jets.
Berwyn
| posted on 10/7/04 at 09:12 AM |
Paul, thats very kind of you. Your most welcome my friend, but dont worry if you can't make it as I will be taking time off work. I have
requested this Friday, but am still waiting for written confirmation. I'll ley you know when it comes through.
Thanks for that snippet Lightning, sounds like that may come in useful.
spunky
posted on 10/7/04 at 09:58 AM |
hydrocarbon test.
This is bloody frustrating to
Lincoln VRO ofice confirmed with me only last week that there is no emissions test at MOT for kit cars, also confirmed with my MOT station.
Infact, after all the tw@ting about to get mine through SVA. When I'm handed the MAC ticket, under CO and HC it states n/a.
The lack of consistancy/communication really winds me up, and I've passed
John
The reckless man may not live as long......
But the cautious man does not live at all.....
J Alderman
| posted on 12/7/04 at 12:37 PM |
On the subject of emmissions
My CBR1000 failed the emmissions at the SVA the first time. Hydrocarbons to high.
To solve this I mearly ballanced the carbs.
the result was a reduction in all the emmissions.
HTH
James
Mk-Ninja
| posted on 12/7/04 at 08:51 PM |
Totaly agree with you Snoopy, the emisions test for BECs is totaly illogical.
I'm sure I've got one, just don't know where I've put it
