Daddylonglegs
| posted on 18/4/11 at 01:03 PM |
IVA Rip Off!
Just been looking at how I'm going to sort the fuel filler and hose for the Locost, and looking on Europa Spares, they have a filler cap and
housing. There are 2 types, one 'standard' and one 'IVA compliant'. The IVA one is £10 more than the standard!
I can't see any difference at all, and there seems to be nothing in the description to explain either. I think some companies are making a quick
buck out of the need to be IVA compliant
mrwibble
| posted on 18/4/11 at 01:09 PM |
why dont you ring them up and ask them the difference?
Bluemoon
| posted on 18/4/11 at 01:15 PM |
Probably a leaded/unleaded restriction plate (read big washer).
Mr Whippy
| posted on 18/4/11 at 01:22 PM |
^ that'll be it
Daddylonglegs
| posted on 18/4/11 at 01:25 PM |
OK, just rang them up, and apparently.....
....The SVA required the restictor (as you guys suggested) but for the IVA, they do not specify a difference because there are next to no fuel
stations left that do leaded so it's not an issue anymore??
Basically, they told me there is no difference between the 2 items.
Which takes me back to my first moan about IVA rip-off!!
If I hadn't asked, I would have assumed I needed the IVA compliant one when I would have got exactly the same product but payed £10 more !!!
adithorp
| posted on 18/4/11 at 01:27 PM |
Does it have the cap tethered?
http://jpsc.org.uk/forum/
Daddylonglegs
| posted on 18/4/11 at 01:31 PM |
Nope, it looks like one where the key stays in the lock until the cap is on and locked.
Mr Whippy
| posted on 18/4/11 at 01:35 PM |
can mind the last time I saw leaded or lead replacement fuel. Don't think the excess valve wear they all harped on about even happened,
certainly I noticed zero difference in my old cars
Daddylonglegs
| posted on 18/4/11 at 02:08 PM |
I agree. I was talking to one of our local Kit Car club last week, and he has been running a 'leaded' Pinto on unleaded for the past
umpteen years, and has not had any issues whatsoever. Let's face it, the amount of miles the average kit car does it's going to take a
hell of a lot of years before any valve wear would be eveident.
Anyhow, I've decided to use the filler cap I already have complete with metal extension (it's the type where key stays in until locked)
and an adaptor from 57-51mm to connect it up to the tank and use flexible fuel filler hose.
The filler was going to have to be on the top of the back cover, but I think the flexible hose should allow me to put it on the back panel instead.
40inches
| posted on 18/4/11 at 02:32 PM |
I have gone for the top cover option, after having a kit with the filler on the back panel that was a pain in the arras to fill
Ben_Copeland
| posted on 18/4/11 at 03:07 PM |
I had my filler in the back panel and it was next to impossible to fill up at the petrol station.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
blakep82
| posted on 18/4/11 at 03:40 PM |
interesting. thought you still had to have the restrictor, but yep, no mention in the manual! saves me another job. i've got a restirctor, but
not got it welded in, now looks like i don't have to
________________________
jossey
| posted on 18/4/11 at 04:18 PM |
IVA approved message.
This message is IVA approved so you will need to pay an extra £5 before you can read it.
:O)
David Johnson
stevegough
| posted on 18/4/11 at 04:29 PM |
I can also confirm that restrictor is not reqd for IVA - just one of the GREAT savings to be made now the IVA is in force
Th
is is the one I bought and fitted, and, as others have said, it is a bit of a pain to fill with it on the back panel - if you get the angle of
the nozzle right, and keep it moderately slow, its not too bad.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Daddylonglegs
| posted on 18/4/11 at 08:36 PM |
Hmm, thanks for the input guys
Not sure what to do now, I like the idea of the rear panel fitting, but if it's going to be a PITA then I might go for the top mounting
instead.
I will also be fitting a rack later, but I think if I place the filler cap correctly I should be able to still fill up without having to faf with the
rack.
stevegough
| posted on 18/4/11 at 08:42 PM |
instead.
rack.
I wouldn't worry too much about it, leggy. It is a bit of a PITA to fill, but I can still fill my tank (& empty my wallet ) in about
a minute !!
[Edited on 18/4/11 by stevegough]
Luego Locost C20XE.
Daddylonglegs
| posted on 18/4/11 at 08:49 PM |
lol! Leggy, good one
I think I'll make a decision on the spur of the moment over a beer or 2, that way if it's a problem I can always blame it on the booze
blakep82
| posted on 18/4/11 at 08:53 PM |
i'm trying to work out how to incoporate a hydraulically adjustable wing flap for the back end, and once the flap is fully open, it then pushes
up the rear cover, essentially a hydraulic fuel filler flap, and so therefor hydralically locking too
the fuel tank has a screw on cap on it, so not fillers on any panels for me!
stevegough
| posted on 18/4/11 at 09:14 PM |
While you're at it, Blake - try and get an automatic - filling tank, too
Luego Locost C20XE.
