Author: Subject: Surely this isn't right......
adampage
posted on 15/8/11 at 09:09 AM Reply With Quote
CATERHAM SUPERSPORT DEDION
ORIGINALLY REGISTERED 1993 BUT COMPLETLY REBUILT 2009
ON NEW CATERHAM METRIC CHASSIS / STARTER KIT, SO NEW CHASSIS, BODY, ELECTRICS & BRAKES
CATERHAM SUPERSPORT 1800 | eBay
If this is still on the original 1993 reg, surely this is not allowed? Is it?
Adam
greed1
posted on 15/8/11 at 09:18 AM Reply With Quote
Doesnt sound right
the original car would now be the doner to a new build
[Edited on 15/8/11 by greed1]
Drive it stright sideways
JimSpencer
posted on 15/8/11 at 09:23 AM Reply With Quote
Hi
Well.. you can replace a chassis on a like for like basis and not require an IVA can't you? (or you could?)
And the bodywork isn't an issue as everybody is constantly changing wings, etc as they get trashed..
So don't actually see why not, its just all been done in one go.
Sevens are like Triggers broom, had half a dozen new heads and several handles but it's still the same old brush
rayward
posted on 15/8/11 at 09:39 AM Reply With Quote
"Well.. you can replace a chassis on a like for like basis and not require an IVA can't you? (or you could?) "
my understanding is the VIN/V5 stays with the Chassis, so technically that car is a ringer
JimSpencer
posted on 15/8/11 at 09:50 AM Reply With Quote
Hi
Just checked and you can replace a chassis on a like for like basis (DVLA.gov.uk site) but you would want to see the receipt from Caterham to be certain the paperwork is 100% correct if you bought it.
indykid
posted on 15/8/11 at 09:51 AM Reply With Quote
You can rebuild a legitimate mini with a heritage shell or a land rover on a new chassis and it still keeps its identity.
I can't see how this is different.
The chassis no should stay with the chassis, but the identity stays with the vehicle as a whole.
The only pertinent part to a 7's identity of those swapped, is the spaceframe. Everything else can be swapped at will. The only grey area is that it's a 'metric' spaceframe. Not sure what difference there is, but it should really be like for like.
posted on 15/8/11 at 09:59 AM Reply With Quote
... and back in the real-world.
As long as the new chassis is a genuine Caterham / Arch / Caged one, the identity on the old one was erased, and the owner had a genuine reason for swapping it, then who cares!
It's Evolution Baby!
adampage
Well I never knew that...
but I suppose the land rover/mini example sounds sensible, so it's probably ok then.
Well you learn something new every day!
blakep82
posted on 15/8/11 at 10:37 AM Reply With Quote
if its being swapped for an identical new chassis, from the same manufacturer, then the chassis number can be transferred without IVA
________________________
mistergrumpy
posted on 15/8/11 at 10:48 AM Reply With Quote
I was thinking about this the other day with a Beetle chassis. The likes of the Eagle and Nova are built on them and don't require IVA'ing. So what if I re did my Beetle with a new floor pan because it's rusted and then used that same Beetle as a donor for my kit car? I've essentially built a new car without the need for any IVA and still played within the rules haven't I?
mcerd1
posted on 15/8/11 at 10:50 AM Reply With Quote
Direct.gov.uk
Vehicles built from a mix of new or used parts
To keep the original registration number of a car or light van that has been rebuilt you will need to use either of the following:
•the original unmodified chassis or unaltered bodyshell
•a new chassis or monocoque bodyshell (body and chassis as one unit – monocoque) of the same specification as the original supported by evidence from the dealer or manufacturer (eg receipt)
You will also need to have two other major components from the original vehicle.
These can be any of the following:
•suspension (front and back)
•steering assembly
•axles (both)
•transmission
•engine
doesn't say anything about keeping the same VIN, but there is nothing wrong with replacing a chassis with a new one 'like for like'
[Edited on 15/8/2011 by mcerd1]
mookaloid
posted on 15/8/11 at 02:40 PM Reply With Quote
Sounds ok to me too
stevebubs
posted on 15/8/11 at 02:50 PM Reply With Quote
Yup...
