rdodger
| posted on 2/11/11 at 11:11 PM |
Steering wheel, airbag, IVA?
Evening
If I use a steering wheel with an airbag fitted but not functioning will it pass IVA?
tegwin
| posted on 2/11/11 at 11:15 PM |
Might raise a few questions from the tester.... but WHY would you want to put a high explosive infront of your face....
You can pickup a second hand non airbag wheel for less than a pint of bitter!
www.verticalhorizonsmedia.tv
rdodger
| posted on 2/11/11 at 11:24 PM |
My choice of donor steering column (mk2 mx5) is steering me in that direction
I'm using it as I am also using the engine and full wiring loom. I'm thinking using a sierra column might end up being easier since that
is the standard fit one.
snapper
| posted on 2/11/11 at 11:51 PM |
Have the exploding bit removed.
By an acredited mechanic.
It's still classed as explosive even if deactivated.
I eat to survive
I drink to forget
rdodger
| posted on 3/11/11 at 09:15 AM |
It's more a case of needing a steering wheel for IVA.
russbost
| posted on 3/11/11 at 01:17 PM |
I have heard of a Mondeo wheel failing IVA for a "sharp edge" - my initial reaction was that it couldn't be a genuine fail as
it's a type approved part, but as soon as you deactivate the airbag function it ceases to be type approved, so if it has a "sharp
edge" will fail! It's a minefield out there!
