cjwood23
| posted on 21/12/11 at 12:44 PM |
What paper work when buying pre-owned?
If you're buying a pre-owned kit that's already been SVA/IVA'd and registered what paperwork should you expect (and legally) be
required to have?
I'm guessing the logbook should match the car - and not still be registered as a sierra or cortina or such like.
______________________
Chris
mookaloid
| posted on 21/12/11 at 12:51 PM |
Same as any other car.
Reg doc and MOT if required.
Obviously it should be correctly registered ie an MK Indy should be called an MK Indy not a Dutton or a Ford escort or a Triumph Herald or a Locust or
anything else - check the chassis numbers have not been tampered with etc. etc.
Do an HPI check check the MOT certificate
look for build history/documentation which establishes that it is authentic.
Mark
